AVIDeMux 2.4.2 freezes on me. It stops responding.
Originally Posted by poisondeathray
Results 31 to 38 of 38
It works for me. I can't see your system specs, if you are on Vista, you might have to run as administrator
To get a video file with no audio, just use vdub, direct stream copy the video, and select audio=>no audio.
You can convert the audio file from vdub/vdubmod to a true PCM WAV with besweet or belight. I just tried this and it works too.
Can I ask WHY are you doing this? Converting a 128kbps mp3 => PCM WAV => 256kbps mp3? You are only losing quality and making it bigger -
Are you sure? Run mediainfo on your belight output file.
It worked for me: the size increased about 10x (from the original mp3) and it reads PCM in mediainfo (not MPEG audio layer 3 like the "fake" wav from vdub)
Did you set it up correctly? Besweet has to be in the same folder
Another option is audacity (free audio editor). Open your demuxed audio file and use file=>export as wav. Tested & working as well. -
Works. Hang me it wasn't in PCM to begin with. Now it's encoding with Lame command. Lol
Thank you to you and everyone else who replied helping me. It was a pleasure. Now we can let this thread die peaceful. Best wishes, thank you again.Originally Posted by poisondeathray
That is already an MP3 file.Originally Posted by rocky12
Some tools for extracting audio from video files (like AVI) just give every audio file a .wav extension.
Just rename it to have an .mp3 extension.
Player with the command line.
By Belini in forum ProgrammingReplies: 2Last Post: 29th Mar 2012, 07:29 -
EAC + lame.exe: sometimes there is 32 kBit/s, sometimes not in command line
By flashandpan007 in forum AudioReplies: 5Last Post: 13th May 2011, 12:36 -
Command-line command for fixing AVI?
By timur in forum ffmpegX general discussionReplies: 1Last Post: 23rd Sep 2009, 03:23 -
In the Beginning was the Command Line
By ahhaa in forum ComputerReplies: 2Last Post: 9th Oct 2008, 12:04 -
command line
By exekutive in forum ffmpegX general discussionReplies: 22Last Post: 2nd Jun 2008, 00:44
