i got a some movies witch are compresed with DivX codec , but my DVD player conected on my TV only read movies with Xvid codec, so i need some good coverter so they will not lose in quality.. pls some help
Results 1 to 14 of 14
You can use AVI Recomp.
But most dvd players supports both xvid and divx.
Have you tried the divx avis? And please also post the details of the divx video, post a screenshot from gspot for example. -
I agree - just change the FourCC from DIVX/DX50/etc. to XVID. DivX and Xvid are basically the same (Xvid began as a fork of DivX), so any conversion or reencode will probably mostly be an unnecessary reduction of quality.
If cameras add ten pounds, why would people want to eat them? -
Originally Posted by Pashata
Originally Posted by jagabo
You might have one of the few players that reject a video if the FourCC is anything other than, say, 'XVID.' (Usually, though, the ones I've read about wanted DivX FourCCs only.
) Offhand, I can't see anything a player might really choke on, though it could always have a problem with the packed-bitstream in the first and VBR audio in the second.
If you have an RW disc, or a blank you don't mind 'wasting,' just use a FourCC editor to change the FourCCs on those videos to XVID (you might have to change the extension on the .divx file to .avi... your player might not see files with that extension, anyway, if it wants only Xvid AVIs) - no need to recompress; you're just changing a few bytes within the videos, burn them to disc, and test the disc in your player.
jman98: Oops, forgot about Divx 3. I think I suppressed that memory.If cameras add ten pounds, why would people want to eat them? -
There may be a VERY simple solution.
Rename them. That post showed the files were .divx files. Just rename them to .avi. The images you posted showed Divx 5 or 6 so it not the old 3.0 Divx.
Possible problem is the packed bitstream, some machines liked packed some don't. I think Avidemux can convert that without a re-encode.
MediaInfo may tell us more than Gspot. The images don't tell us if Global Motion compensation was used for instance and that doesn't work in any DVD player I have heard of. Same for Qpel. -
Thanks Ethlred , i'll try avidemux... Ai Haibara what should i chose from the dropdown menus in FourCC editor to change it in xvid , there is mp41 , mp42 , mp43 , DIV4 ..
this is what showed MediaInfo:
Code:General Complete name : D:\Movies\Vratice se rode 4\1980283.divx Format : AVI Format/Info : Audio Video Interleave File size : 350 MiB Duration : 45mn 54s Overall bit rate : 1067 Kbps Writing application : VirtualDubMod 1.5.4.1 (build 2178/release) Writing library : VirtualDub build 28225/release Video Format : MPEG-4 Visual Format settings, BVOP : Yes Format settings, QPel : No Format settings, GMC : No warppoints Format settings, Matrix : Default Muxing mode : Packet Bitstream Codec ID : DX50 Codec ID/Hint : DivX 5 Duration : 45mn 54s Bit rate : 929 Kbps Width : 640 pixels Height : 368 pixels Display aspect ratio : 16/9 Frame rate : 25.000 fps Resolution : 8 bits Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.158 Stream size : 305 MiB (87%) Writing library : DivX 6.7.0 (UTC 2007-09-20) Audio Format : MPEG Audio Format version : Version 1 Format profile : Layer 3 Codec ID : 55 Codec ID/Hint : MP3 Duration : 45mn 54s Bit rate mode : Constant Bit rate : 128 Kbps Minimum bit rate : 128 Kbps Channel(s) : 2 channels Sampling rate : 48.0 KHz Resolution : 16 bits Stream size : 42.0 MiB (12%) Alignment : Aligned on interleaves Interleave, duration : 40 ms (1.00 video frame) Interleave, preload duration : 504 ms Writing library : LAME3.97 Encoding settings : CBR
I believe it should be 'XVID'.
(Also, just to be safe, on all files with the .divx extension, give them the .avi extension instead, as mentioned above. The .divx/Divx6 features won't do much for your player unless it's DivX Ultra-certified, anyway. Your player probably won't recognize any file with that extension, at any rate.)If cameras add ten pounds, why would people want to eat them? -
so i need something quick , it should be AVI fourcc code changer , but i don't now how to use it.. can u help me , what should i peek from dropdown menus so i can change the video to Xvid
Renaming .DIVX files to .AVI should help.
MPEG4Modifier (no re-encoding) can be used to remove packed bitstream if that's a problem.
I've seen a few mobile devices that require all keyframe Xvid. If you have one of those you will probably have to be re-encode with VirtualDub or AviDemux.
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 09:11 -
Would synch mostly occur on DVD to DivX, or XviD to DivX?
By rocky12 in forum Newbie / General discussionsReplies: 3Last Post: 29th Oct 2008, 01:01 -
Does divx author reencode Divx and xvid files?
By Onceler2 in forum DVD RippingReplies: 4Last Post: 26th Aug 2008, 18:16 -
Weird I don't have XviD or DivX codec installed but I can see Xvid movies
By Talayero in forum Software PlayingReplies: 4Last Post: 5th Jun 2008, 11:47 -
Make an unplayable Xvid/Divx video play in a divx standalone Player
By AllenGorden in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2007, 17:25
