hi,
I am having a serious problem. I did a dvd where the root menu is running a tad tooo fast that is the video is running very fast and the audio sounds like the chipmunks are singing. I seriously don't know the problem. I tried different burners and lower burning speeds. The video_ts file is playing slow but when I burn it is running fast.
I hope you all can help me out
Results 1 to 10 of 10
How's My English?
I burnt a few dvds like 3 days before and they were good. Now the root menu is playing in a chipmunk way
How's My English? -
Your problems don't sound to be burning program related.
How did you create your DVD files that you burned?ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
From your first post I assumed that the main feature is running fast also.
If that is the case, I had this happen once, when other program started to look for an update during burn. -
yea I had alot of programs running when I authored and burnt it
How's My English? -
If your authored file play OK on your computer, then try to re burn with all the progs shut down.
Guide for extracting menus for editing, and reinserting edited menus
By manono in forum Authoring (DVD)Replies: 167Last Post: 8th Dec 2022, 03:44 -
Menus folders or sub-menus
By GymDad in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 9th Nov 2008, 08:43 -
Speedy playback
By MasterThomasMI in forum Newbie / General discussionsReplies: 12Last Post: 29th Dec 2007, 13:25 -
Magix Movie Edit Pro Menus and Sub-menus
By gayclarke in forum Authoring (DVD)Replies: 8Last Post: 11th Aug 2007, 11:07 -
Menus
By mingul in forum Authoring (DVD)Replies: 4Last Post: 19th May 2007, 07:42
