Hello everyone
I borrowed a Sony DCR-PC110E handycam from a friend to shoot some video footage.
The problem now is how to transfer the video from the miniDV tape to the PC...
I've read much articles and forum posts over the net about this and concluded that the ususal/proper way is via the firewire cable (or so called I.Link), although in some places I found that in general this can also be done with the USB port (which by default is used to access the memory card) at a cost of a slightly lower quality...
If I want the "firewire way", I have to drive over to the shop (which isn't near) to buy the cable...
So I would like to check with you guys is this possible via USB? (I'll be using Adobe Premiere CS3 for capturing)
	According to the user manual, the USB option is used exclusively for MemoryStick operations. Taped material can only be sent via FireWire. John Miller
  Transfering Video from Sony DCR-TRV250 by USB on Win7 64-bitBy madadivad in forum Capturing and VCRReplies: 5Last Post: 7th Dec 2011, 17:52
  Easycap Video Grabber Capture card USB 2.0 RCA and S-Video?By ffxdean in forum Capturing and VCRReplies: 149Last Post: 16th Mar 2011, 02:02
  USB Stream from Sony DCR-HC42By bozzel in forum Newbie / General discussionsReplies: 10Last Post: 11th Mar 2009, 16:23
  Questions for Improving Sony DCR-TRV22 Video Capture SupportBy fredberry in forum Capturing and VCRReplies: 3Last Post: 2nd Nov 2008, 15:59
  capture advice: USB 2.0 video capture adapter?By j jasper in forum Capturing and VCRReplies: 10Last Post: 26th Feb 2008, 20:18
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
