hi
i've got a little problem![]()
i shot some footage with canon's somekind of DV camera - it has a big lens, a 2 way microphone etc...
when i imported the video into my PC i didn't know anything about the fps, aspect ratios etc..
so now i have a video that has a resolution of 720x576 and fps is 25.00 (i got it into the pc somehow by watching the filesize and quality etc... and everything seemed ok)
when i started a new project in premiere, i didn't pay attention to the fps and i just created a timeline with fps 29,97
profile might be microsoft dv avi or smth...
i found out the resolution difference as well while exporting the finished movie and then saw that the fps was wrong as well :\
now i'm like a cow stuck in a barrelif i put the resolution right then it creates a movie with all the sound running behind littlebit. and when i get the sound right (by using somekind of default export values) then the sound is in it's place, but resolution is not right... :S
is there a way to automatically change the timeline to 25 fps without losing the music/video sync?
when i click on the Sequence 1 in premiere, it shows the resolution of 720x480, but when i export it with the same values, the sound is running behind. (i'm using huffyuv as the lossless stuff :P)
thanks!
PS: the project file is like 2MB and the video itself is 12 minutes.
so it was quite a bit of work putting 2hrs of footage into that...
Results 1 to 1 of 1
Adobe Premiere Pro CS3 & Vegas Pro help
By KS89 in forum EditingReplies: 1Last Post: 8th Sep 2009, 22:52 -
SxS Pro card file MXF to DVD using Adobe Premiere Pro CS3
By Fary4u in forum Video ConversionReplies: 8Last Post: 20th Jul 2009, 09:00 -
logitech pro 9000 captured video to premiere pro CS3?
By yunakokimama in forum EditingReplies: 1Last Post: 15th Oct 2008, 16:27 -
Timeline Preview - Vegas Pro 8 vs. Premiere CS3
By SCDVD in forum EditingReplies: 2Last Post: 15th Aug 2008, 12:29 -
Importing a Photoshop CS3 image into Premiere Pro CS3
By paulinnorway in forum EditingReplies: 4Last Post: 17th Apr 2008, 07:54
