Just a little question: I make svcd's from dvd rips of dbz epz (and they look great btw) following the way at http://www.doom9.org/mpg/avi2svcd.htm , but instead of vbr I use CQ at 100, minimun and max bitrate at 2500, burn it at 4 speed with Nero.
The standard buffer is 112 KB (Tmpgenc) Would it stop the occasional jerking/stopping for a frame/simular situations if I double the buffer? I learned quite a lot of tmpgenc but none of the infosites have any info about the buffer stuff.
I also get (sometimes) that the image is R E A L blocky for a split frame or so (it's 2 fast for me to time :P) but obvious nontheless..
Legendary Super Newbie!
Build a man a fire and he'll be warm for a day. Set a man on fire and he'll be warm for a lifetime.
Pretty women make us buy beer, ugly women make us drink beer. -
What you describe sounds like a buffer underflow.
The standard buffer size should be 112 segments= 224 KB. The higher the range between min and max bitrate and the more B-frames you set in the GOP structure, the higher the VBV buffer must be set.
If you want to make SVCD (MPEG-2 / main profil & main level) use in TMPG 224 KB. -
I don't do anything in the GOP stucture and settings, that is still abracadabra to me. I'll increase the buffer, and try it out
thnx
Truman (if you are reading this!),
I have noticed that TMPGEnc sets the VBV to 112 for SVCD, but checking the file with Bitrate veiwer shows only 56. Is this the sements vs kB you were refering too? I tend to always double the value in TMPGEnc, from what it has as standed so that I get what I suppose to be the right result in Bitrate viewer (ie SVCD 112kB ). Is this right????? -
Bitrate Viewer tells you the VBV buffer size in segments. 1 segment = 16 Kb (16384 bits, not bytes). In TMPG you set the VBV buffer size in KBytes.
Short said, yes, you are right.
In most TMPG SVCD templates the size is set to 112 KB, that may be too low in many cases.
Encore increasing timeline size
By koberulz in forum Authoring (DVD)Replies: 47Last Post: 9th Nov 2011, 11:19 -
What is buffer size?
By dzsoul in forum Newbie / General discussionsReplies: 1Last Post: 6th Dec 2009, 09:04 -
buffer size 25000 in ripbot
By miss in forum Video ConversionReplies: 7Last Post: 4th Sep 2009, 09:07 -
Adding subtitle to xvid without increasing file size of the .avi?
By Kromgol in forum Newbie / General discussionsReplies: 3Last Post: 19th Jul 2009, 12:03 -
buffer size question
By socalkev in forum Newbie / General discussionsReplies: 0Last Post: 26th Sep 2008, 16:36
