Have transfered some Dv footage via windv as an avi file. All seemed well when transferering, could see picture & hear sound on WINDV, but when playing back the AVI through Windows media player there is no sound??
I chose "type 2 vids & Auds" on the capturing menu, as I read in one the guides on here.
Does anyone know what im doing wrong?
The audio track is there as I have also transfered it via Cyberlink power director & it played back no problem. It is dv from my camvorder.
Just checked, there is no sound in vlc Player either & G spot says the audio codec is pcm -
Some dv camcorders are set for 12bit recording, while many players and editors work with 16bit. Check the audio default settings on your camcorder.
if you are using powerdirector, it has a nasty habit of grabbing all audio and not releasing it until you close it. try again after shutting down powerdirector.
Any Win 98SE gurus here? Sound card problem =(
By sdsumike619 in forum ComputerReplies: 16Last Post: 26th Sep 2011, 21:32 -
prob megui with win 7 T.T
By lainexperiments in forum Newbie / General discussionsReplies: 8Last Post: 30th Jul 2010, 05:00 -
prob joining VOBs; also sync prob with another movie
By spiritgumm in forum EditingReplies: 5Last Post: 19th Jun 2010, 10:32 -
Sharp Mini DV firewire not detected by Win 7 but was working under Win XP.
By thintin in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 6th Jun 2010, 03:12 -
sound prob on dvd from mkv
By umpaflumpa in forum Video ConversionReplies: 2Last Post: 20th Dec 2007, 12:02
