Hi, ive just transfered some dv footage from my camcorder to my pc as an avi file using Cyberlink powerdirector.
All seems ok, but i have 30 mins of video & it is a massive 6.5 gig!
Is there another way to do it so it is a smaller size?
Also if I now wanted to encode this to MPEG to make a dvd it would be too big.
I dont really want to lose quality, so what is the best thing to do?
Many Thanks in advance
Paul![]()
DVavi is 13gb/hr. that's the way it is on the cam tape. doesn't make any difference if you are going to encode it to mpeg-2 anyway for dvd. follow the instructions for making a dvd in powerdirector and it will convert it for you. 30 minutes of DVavi is about a third of a dvd.
Ok, so that is the way it is meant to be? So if I want to put Dv footage on my pc as avi files, Ive just got to accept that they will be big files?
Could I just ask one other thing. So what do I do if I want to keep loads of DV footage on my Computer, the hard drive would fill up in no time??
external usb or firewire hard drives are fairly cheap. or do what most folks do and keep the original miniDV tapes. they will last longer than any hard drive anyway. if you buy them when they go on sale for about $2/each it's not bad.
.avi to .mov gives me a 0 kb size file
By kusuri in forum ffmpegX general discussionReplies: 3Last Post: 10th Oct 2012, 12:14 -
MeGUI: Problem calculating AVI file size
By fakecake in forum Newbie / General discussionsReplies: 9Last Post: 1st Feb 2009, 08:11 -
Reencoding to reduce the file size of an AVI (xvid) file
By DVantrease in forum Video ConversionReplies: 7Last Post: 10th Jan 2009, 20:56 -
Decrease the size of an avi file
By mierdatuti in forum Newbie / General discussionsReplies: 3Last Post: 5th Oct 2008, 11:51 -
File size problem with TMPGEnc [.avi to .mpg conversion]
By Timex in forum Video ConversionReplies: 7Last Post: 26th Jun 2007, 21:50
