Help! My cd-rom will not read the VCD. I burnt the mpeg file with Nero 5.5. There is nothing wrong with the file when it is on my PC. After the burning process succeed, I tried to play the CD on the sand alone VCD player, it said no disc. CD-rom on PC cannot read the disc too. I followed exactly the procedure in the column to make the mpeg and burn. Could someone tell my why?
R U sure that your player can read CDR's
Check the standards on this web site for your DVD player. -
As odd as that sounds...it happened to me last night. I burned the And1 Mixtape Vol. 4 and according to Nero (5.5) it burned successfully. So I tried to play it in my computer-nothing. I tried my DVD player-nothing. It never really burned. So I just reburned w/out any problems and all was good.
Had faced the same problem, as I was burning the file into a rewritable CD , the same is not recognised by CD player.
Check if this is the problem -
I am in a similar situation. Burned 3 svds(s) w/nero5.5.
1. memorex cdr encoded by TMPGEnc
2. memorex cdr encoded by Pinnacle Studio 7
3. hp cdrw encoded by Pinnacle Studio 7
All three play well on standalone pioneer dvd player.
None of them play on my cd-rom OR my hardware dvd player on my computer system. Unrecognized format.
My computer based dvd uses asusdvd software. (I notice there is a file in that folder named powerdvd.exe.) Opening both mpeg2 files via windows explorer opens wmp where they run smoothly.
Any ideas or references I could check?
thanks,
kristin
CD-ROM vs. DVD-ROM
By Judson in forum MacReplies: 10Last Post: 6th Apr 2012, 08:33 -
RAM not recognized
By videobread in forum ComputerReplies: 4Last Post: 27th Nov 2011, 11:34 -
BD-Rs are not recognized
By orfajackson in forum Newbie / General discussionsReplies: 1Last Post: 23rd May 2009, 17:43 -
Newbie question about VCD files for CD-ROM
By donn in forum Newbie / General discussionsReplies: 2Last Post: 13th Apr 2008, 17:37 -
Cd-r not recognized
By cd090580 in forum DVD & Blu-ray WritersReplies: 14Last Post: 27th Feb 2008, 03:03
