Well I'm pretty new at this but my advice would be to either purchase or do a "search" for winoncd 3.7 or 3.8, power edition, this program is a godsend for people who want to create picture disks. It creates thumbnails with backgrounds, a title page, and in the 3.8, (i have 3.7)edition i hear that you can even add background music. the only caveat i have with this software is that it converts all your images to bmp's which takes about 20 minutes on my pentium II 400.
Hope this helps.
Where is the wine the new wine? Dying on the vine.
I cannot make comment on NERO as I do not use it.
You should be aware that Windows Media Player 6.4 will play .dat files. Be warned however that sometimes the 1st dat file is not one that you have encoded - it may well be an intro sequence built into the writing program for cdi's. I used to have this problem, try to play it and everything would go screwy.
So update to 6.4 version of Media player - stay away from 7 if you can.
Audio and VCD can does have different properties so your logic does not stand up - but I hope you are correct.
On my website, http://www.coyote01.freeserve.co.uk I have included a intro logo in the correct PAL format, download it, rename the extension to .mpg and burn as VCD. If it plays OK your DVD supports CDRW VCD.
I use WINONCD 3.8 Power Edition for my photo albums. This does absolutely everything I would want a photo album to do on my DVD Player.
Hope this helps
Using digital photos in DVD movies.
By Craig Taylor in forum Newbie / General discussionsReplies: 2Last Post: 3rd Mar 2011, 05:35 -
Putting all of my digital photos on a DVD for archives
By hardy in forum Off topicReplies: 3Last Post: 22nd Sep 2010, 15:32 -
Viewing and storing photos/video on CD/DVD
By Mellie in forum ComputerReplies: 9Last Post: 8th Jan 2010, 14:24 -
Viewing Photos On A DVD On TV
By joedough in forum Newbie / General discussionsReplies: 1Last Post: 19th Feb 2009, 11:37 -
Convert my digital photos to a DVD
By hufri01 in forum Authoring (DVD)Replies: 5Last Post: 7th Mar 2008, 06:16
