I'm looking for regular DVD-Rs but I want them to be silver instead of the usual purple. I have heard some comment on the existence of such DVD-R. If anyone know I would appreciate to know where I can get them.
Thanks in advanced!
Royalty Free Visual FX & Stock Footage
http://www.motiondrops.com -
Some brands of CD-R and CD-RW look silver because of the dye used, but no DVD+/-R discs look like this. All DVD+/-R discs basically use the same purplish dye because it's the only thing that works. There's a little more flexibility with CD-R discs as multiple types of dyes work with them.
Nowhere - not even MAM-A Gold (or Silver) have "gold" or "silver" bottoms: They're purple like all the rest.
;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
Thanks for the info. I had the feeling it was not true, but technology is changing so quick that I had to ask. The person who told me this is a tech guy who is so good that everyone go to ask for him and always 100% right. I guess he was wrong this time
Thank you again. Cheers.Royalty Free Visual FX & Stock Footage
Originally Posted by Motiondrops
You can pay for pressed DVDs which will be silver because they are pressed, but that's not really what you asked about. Pressed DVDs is how commercial DVDs are made and you asked about DVD-R, which is consumer burnable.
minted dvd with ding in silver part
By spiritgumm in forum MediaReplies: 6Last Post: 20th Jun 2011, 23:13 -
Buy DVD's with silver recording side?
By btlover in forum DVD RippingReplies: 26Last Post: 31st Aug 2010, 22:20 -
dvd burner with silver lacquer dvds
By hardy in forum Newbie / General discussionsReplies: 3Last Post: 1st Apr 2010, 11:11 -
DVD+R Double Layer Matt Silver 8x Made in Taiwan?
By kyrcy in forum MediaReplies: 5Last Post: 7th Dec 2009, 10:20 -
looking for silver hub printable DVD media
By PharmBoy in forum MediaReplies: 6Last Post: 30th May 2008, 05:31
