  1. Well, if you take a look at the video I've attached, you can see in the second half of it, a red wipe comes from the left. What I want to do is change the red font into black as the red wipe goes over it.
    I thought it'd be a real simple task, but I've been busting to figure it out.
    Help would be greatly appreciated.
    Adobe Premiere CS3.
    opening.m1v
    Apr 2004
    Miskatonic U
    The simplest method would be to have the two versions on separate timelines, then simply wipe from one to the other
    Read my blog here.
  3. what's an XOR filter?
    wiping doesn't seem to work,
  4. Exclusive Or:
    0 xor 0 = 0
    0 xor 1 = 1
    1 xor 0 = 1
    1 xor 1 = 0
