DOes anyone know of a converter (that works which isn't SUPER or 4U AVI MPEG Converter or AVD Video Processor 7.7 TRIAL or Magic Video Batch Converter or Ulead Videostudio ) that can batch convert multiple widescreen videos which are all similar but different sizes and are about 50 minites each but one is 65 minuites each into Adobe Premiere Pro compatible, as anyone I am looking for as little quality loss as possible and as small as possible as these will be on my HDD for a while. but it can be in total a maxmum of 50 gb but all 13 files files will be in use in the project as it is a very long trailer / hightlight reel. Plus other thingsin it. It must be able to convert from XVID and DIVX (both CODECS are installed) OR could you just help me fix the problem in Adobe itself. Unfirtunatly you might get nothing out as it says the audio CODEC isn't supported . So any ideas?
If I understand correctly you have a batch of AVIs with various resolutions and length which you would like to convert into a common parameters before prpcessing further.
You could use Mediainfo or GSpot to check what kind of codecs are being used and try do download+install them onto your computer. If they are AVIs created from capturing DV tapes then a Mpeg2 codec might be needed.
For batch conversion I would use VirtualDub. Create a desired set of processing settings with your first AVI, save it for the next use. Save your desired avis in batch mode by VirtualDub and take some time for coffee or beers. But for sure you will get good quality output.
Converting 10-bit to 8-bit MKV (?)
By valp in forum Video ConversionReplies: 2Last Post: 6th Jan 2012, 15:55 -
64-Bit Vegas Pro 9 fails to open 64-bit UT Video Codec Pack
By Smells_Like_Feet in forum EditingReplies: 1Last Post: 2nd Oct 2011, 15:14 -
Basic direction, editing, converting HD video
By TexIndian in forum Newbie / General discussionsReplies: 2Last Post: 1st Jun 2010, 13:30 -
Converting Video TS into a basic AVI or MPEG
By nadizo in forum Video ConversionReplies: 6Last Post: 3rd Sep 2009, 00:41 -
Converting 32-bit audio to 24-bit
By Colmino in forum AudioReplies: 10Last Post: 29th Oct 2007, 18:22
