I export a frame from Premiere Pro CS3. It's an HDV 1080i 50i project. The project says the dimensions are 1440x1080, and everything looks right in the preview and timeline windows. I export a frame and it's dimensions are reading 1440x1080 in Photoshop, but it is clearly not wide enough. I transform and resample the image to 1920x1080 and that looks right. What's going on here? Why are my Premiere project settings not 1920x1080? Thank you!
could it be because your camera records at 1440x1080? that would be HDV spec 1080i. it 's a wide pixel format.
Any image editing software can rescale the size of the imported image as needed. For an HDV frame, you need to scale horizontally by 1.3333 and leave the vertical dimension as is. You can probably specify the new scale in pixels, inches, centimeters, percent etc. Easiest is to simply rescale the image pixel dimensions to 1920 x 1080. Which, of course, it what you have been doing!
It will mean resampling but only in the horizontal direction which isn't really an issue. When you display HDV on a widescreen TV etc, the TV is doing the very same thing anyway.
CS 5.5.2 fails to export HDV footage to tape/perplexed
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 6Last Post: 19th Apr 2012, 21:41 -
XH-A1 vs HV-30 HDV export to tape results/Which model is best?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 3Last Post: 23rd Aug 2010, 21:33 -
HDV project final export
By kippard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 15th Oct 2008, 04:02 -
Premiere Pro CS3 HDV export
By kippard in forum EditingReplies: 0Last Post: 12th Oct 2008, 20:30 -
HDV export in FCE
By Vralteladden in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 30th Jul 2007, 16:41
