I have a few videos in .vob extension, but I know I need .bup and .ifo files for able to burn on a disc. Does anyone know how?
Results 1 to 27 of 27
How did you get the VOBs? All VOBs come with IFO and BUP files. DVDs can't play without them.
You can use IfoEdit to recreate the IFO and BUP files. A BUP is a backup of the IFO files and the IFO files include information such as chapters, subtitle tracks and audio tracks. The VOB files contain the actual movie, subs and audio tracks.
See 'WHAT IS' DVD to the upper left on this page for a explanation of the structure, format and technical info about a DVD. You can also re-author the VOBs to create a DVD from them. A program like GUI for dvdauthor or similar can do that.
Run them through FixVTS.Originally Posted by showmiLooking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com
I've only tried this a handful of times, but it hasn't failed me yet.Originally Posted by jman98Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com
Is it mandatory to have .IFO files and .BUP files for a DVD Player to play the movie ?
4 years later....the answer is still YES and the answer is easily found by a simple search:
https://www.videohelp.com/dvd#struct -
I have a movie with me with only .VOB files. It plays on the computer. So I guess I have to generate the .IFO and .BUP files to play in the DVD Player. Is IFOEdit the software to use to generate the .VOB files ?
Also one of the files VTS_01_0.VOB has only sound and no video. Towards the end, it displays a menu and after one second vanishes. So what do I do now ? -
No. Needed to tell your player that there's no menu.Some say, that if you don't want the menus and chapters and other navigation options, you can do away with the .IFO and .BUP files even while playing on a DVD Player.
It's because it's a menu.Also one of the files VTS_01_0.VOB has only sound and no video. Towards the end, it displays a menu and after one second vanishes
Beside VTS_01_0.VOB you would have VTS_01_1.VOB, VTS_01_2.VOB ...So I guess I have to generate the .IFO and .BUP files to play in the DVD Player. Is IFOEdit the software to use to generate the .VOB files ?
You could use DVDStyler to author a DVD. Drag VTS_01_1.VOB onto it and add the remainder as Chapters by rigth-clicking.
If you don't want a menu but have the DVD play when inserted in the player use:
DVD -> Options -> First Play Commands -> jump title 1; -
But then, it plays for around 1 minute and 30 seconds and during this period there is no video. But the soundtrack corresponds to VTS_01_1.VOB for the aforesaid time period and it is only for just one second, the menu flashes and is visible, after that it stops playing. Nobody can even read the menu in such a short time. What is the reason for this and how do I fix it ? Obviously I cannot burn a DVD with this kind of VOB file. I am not sure of the quality of the few IFO and BUP files that I see. They are VTS_01_0.IFO and VIDEO_TS.IFO and their respective BUP files.
So what? You're playing the menu as a VOB file and not as a DVD. And you can't play it as a DVD because there are no IFOs. It sounds to me like there's a static menu with associated audio, but it's useless to you.
You can make a DVD from the movie VOBs using IFOEdit or Simple DVD Creator, but unless you know something about menu commands I doubt if you'll be able to figure out how to make a working menu for it using what you already have. You could always create a new working menu using any one of a number of different DVD authoring and menu creation programs. -
??? You wrote:I am not sure of the quality of the few IFO and BUP files that I see
appearently you also already have the .IFO/.BUP. Sounds to me as if you actually have the whole DVDI have a movie with me with only .VOB files. It plays on the computer. So I guess I have to generate the .IFO and .BUP files to play in the DVD Player -
Yes. You are right. If I click the one and only .IFO file, this static menu is launched with the soundtrack in the background. If I click the play option, the movie plays automatically. I never knew you could play a movie by clicking on the IFO files. I usually click the huge .VOB files in ascending order to play the movie.
Yes. And I guess it is fine and playing well. Sorry for troubling you guys. But I also learned a lot about how DVDs work, my special thanks to hech54 for the link.
And to manono for information about the softwares.
And to videobruger for pointing me in the right direction. So one last question. Why do I have two .IFO files ? VIDEO_TS.IFO and VTS_01_0.IFO and their respective backups ? Clicking on either of the IFOs plays the static menu with the associated soundtrack. -
Take one more look at the link provided to you by hech54So one last question. Why do I have two .IFO files ? VIDEO_TS.IFO and VTS_01_0.IFO and their respective backups ?
By the way, there was no AUDIO_TS folder. Can I create and empty folder by that name so that I match the expectations of the DVD Player ?
I did take a look, though after typing the question and it says, VIDEO_TS.IFO is for the menu and VTS_01_0.IFO is for the main movie. But both .IFOs lead you to menu only and from there I can do whatever I want, play or go to specific scene selections. So I still do not understand why there are two of them, performing similar roles.
Random stupid Question I've downloaded a movie from a torrent website and its a .mp4 file, is there a way to get the necessary .bup, .ifo files to burn it to a dvd?
Thanks for any help. -
An MP4 file is very unlikely to have the correct video codec necessary to put straight into DVD-video format. And even if it did have compliant mpeg2 video, you'd still have to author it to that format.
You should use AVStoDVD to convert it. AVStoDVD is free, and simple to use. You're in Ireland? Make sure to set up AVStoDVD to output to PAL standards. You'll have that option when first starting up the program. I also advise using the HC encoder that is included, and use a two pass encode.
Once AVStoDVD is finished making the DVD-video for you, I'd advise burning to a disc with ImgBurn.
Need to make IFO, BUP for Single VOB
By Simmons in forum Authoring (DVD)Replies: 5Last Post: 28th Aug 2011, 21:15 -
How do I make a dvd data disk from these vob, bup, and ifo files?
By DHarry in forum Newbie / General discussionsReplies: 4Last Post: 4th Jul 2011, 05:23 -
Question for .Bup & .Ifo files..
By Pleochoric in forum Authoring (DVD)Replies: 4Last Post: 31st Oct 2008, 06:33 -
How to play a .vob .bup .ifo files?
By Kinstonian in forum Software PlayingReplies: 12Last Post: 19th Mar 2008, 17:26 -
Padding IFO/BUP files to 32kb in OS X?
By Cyrax9 in forum MacReplies: 3Last Post: 14th Jun 2007, 16:46
