I accidentally switched the video option menu to PAL and now I cant get a signal on my TV so I can switch it back to NTSC with the remote. Does anyone know of an easy way to do this?
Hmmm....I haven't used my old APEX 1500 in awhile....Try this unplug power cord of your APEX unit for a minute or so....Then plug it back in and then power up the unit.....Go to the menu selection again and choose NTSC. I once had a similar problem and that's what I did to get NTSC back up. Good Luck! If that doesn't work then check out the APEX FORUM....do a search in GOOGLE for it.....That forum does exist!
Sysman, on your remote, you should have a P/N button.
This button switches between PAL, NTSC and Auto Modes.
Good Luck.
How to switch FFDSHOW back on.
By eldobkram in forum Newbie / General discussionsReplies: 3Last Post: 4th Dec 2009, 14:37 -
Mode switch alignment - requst to Panasonic VCR owners !
By abbymat in forum RestorationReplies: 0Last Post: 29th Apr 2008, 14:27 -
Apex AD1250X Owners?
By nemesys23 in forum Newbie / General discussionsReplies: 3Last Post: 1st Jan 2008, 18:36 -
display problem switch from pc to tv, can't switch back
By samiam5156 in forum ComputerReplies: 1Last Post: 11th Oct 2007, 10:23 -
What might make Windows switch a DVD drive to non-DMA mode?
By EddyH in forum ComputerReplies: 8Last Post: 1st Jul 2007, 23:35
