Hi
How many percent do I have to put if I want my movie to show on my TV (4:3) in full screen.
I tried 10% and I can see the subtitles on my movie but I cannot see parts of the images vertically.
Video Info:
640*480
How long is a piece of string ?
Before you get too excited about overscan, understand that every TV show and DVD you watch also has parts of the image hidden from you. TV shows are in fact shot with this knowledge in mind, and so nothing of importance is placed at the edges of frames.
That said, if your source is fan-subbed anime, then yes, you probably will have a problem as fan-subbers only sub for PC playback, not TV playback.
The problem with your question is that there is no absolute answer. The overscan area varies from TV to TV. On some it is very small (on mine it is 3 - 4%) and on other TVs, as much as 10%. Also, it may no be symmetrical.
Generally, 5% should be a good compromise for most decent quality TVs. However you may have to do a test run to see what suits your TV.Read my blog here.
With CRT TVs overscan varies with the picture content, the temperature, and the age of the TV, and other factors. In fact, this is why they overscan.
As the other answers imply, you are asking for a specific answer to a general question. Televisions do not overscan by precisely equal amounts. The very reason for overscan at all is that manufacturers cannot guarantee the consistency of the amount of scan area, so they conservatively choose sufficient overscan so that no TV goes out the door with any underscan. Consumers will return TVs with the tiniest underscan, but not overscan.
So, you could measure the amount of overscan that your *particular* TV exhibits, and encode with that knowledge in mind. However, you must understand that this choice will not necessarily be appropriate for a different TV. Worse yet, your TV's overscan may vary with local mains voltage, temperature, average screen brightness, and many other factors. -
Use a DVD-RW or sacrifice a DVD-R and create a DVD using the following image as either the movie or as the menu background. There are others like this and probably better so do a google search but this one will work:
http://hifinet.co.kr/images/uploads/overscan_filtered.jpg
DVD flick
By Pumkinhead in forum ComputerReplies: 15Last Post: 5th Dec 2011, 12:11 -
DVD Flick
By stonesfan71 in forum Newbie / General discussionsReplies: 1Last Post: 14th Dec 2010, 20:45 -
dvd flick
By bloodymoon6 in forum Video ConversionReplies: 2Last Post: 4th Feb 2010, 19:43 -
DVD FLICK
By sm173 in forum Video ConversionReplies: 2Last Post: 29th Mar 2009, 15:32 -
Using DVD-flick
By Meagain in forum Newbie / General discussionsReplies: 6Last Post: 24th Mar 2009, 10:36
