Hi,all!
I use TMPGEnc2.50 and would like to convert 3GB-mpeg (1 h.30min) _file in SVCD as usual, everything is OK, but everytime TMPGEnc2.50 get only (35min) decoding!
It wasn't into early TMPGEnc-versions so, would always to decode 3GB or 4GB or 5GB like whole one made!
What must I change, thus whole film be decoded?
SKeeper
copy the templates from the plus version to the folder you use and select the wizard (gives a few choices then) or check your pm for a link to get the plus
SKeeper:
I discover that since version 2.5x, TMPGEnc has a min default value of 2000 Kbps when encoding with VBR. This will increase your encoded file about 30-60 % depending on the template use. So I recomend you to use previous versions...
Antonio S.
http://www.antonio.owns.it -
doesn't workig for me!!!
perhaps there is extra adjusting for this?
identical, which TMPCmt version is now,so it makes only 30 min decoding of all from 1h 30min Film!
What can i do?
SKeeper -
What can i do?
SKeeper -
Hi,all!
perhaps have I printed wrongly what I want!
I will to try once again with my question, so (I have 2 different Mpeg2 files,(this mpeg2-files was made with mine Sat-digital Receiver Nokia9600scsi)
first mpeg2 file is- 3.07 Gb,
second mpeg2 file is- 3.05 Gb
wenn i load first-file with TMPGnc2.02, there in Programm, where stand:
Progress
Whole -------------------0%------------------------- 0 / 138235
this 138235 it is OK!
and will decoded to
SVCD a 100%
whole 1h 30min film!
But wenn i load second-file, there is only stand so:
Progress
Whole -------------------0%------------------------- 0 / 44548 ?????
hier is only 44548?
and will decoded
only 30min from
whole 1h30min
Film!
Question is: why almost at two like files, one not goes correctly?
Please, any solution?
RGRDS
Skeeper
Decoding LG HB966TZ
By mikestar in forum Blu-ray RippingReplies: 2Last Post: 20th Oct 2011, 04:19 -
Help in CAVLC decoding
By krao in forum ProgrammingReplies: 0Last Post: 15th Jul 2010, 16:55 -
subtitles gone after decoding
By Meredy in forum SubtitleReplies: 1Last Post: 7th Jul 2009, 07:52 -
Xvid4PSP and DD decoding
By CineManno in forum Newbie / General discussionsReplies: 8Last Post: 25th Jan 2009, 11:55 -
DTS Decoding
By Neutral-Sage in forum AudioReplies: 8Last Post: 17th Nov 2007, 02:16
