I have an Asus M3A board, Phenom 9550 Quad 2.2 Ghz processor. I've been getting memory mapping error, each time I open up Asus Probe II,.
Can someone check out my figures and tell me if my memory is functioning properly. The ram is Crucial 800 Mhz 6400,.
By waterspirit at 2008-07-13
Did you adjust the ram settings? Is it set to AUTO within the mobo bios?
Thanks for reply. No, I don't know how to set the memory in the Bios.
Go into the motherboard bios and look for the memory settings. Set them to AUTO.
or better yet go into the bios and hit <F5> "load system defaults" answer yes, save and exit.
that will load all the safe settings for your computer motherboard.
Questions regarding recording settings and compression settings
By so in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2011, 07:45 -
Vegas 8 - "System low on memory. You may be able to reduce memory usag
By sdsumike619 in forum EditingReplies: 12Last Post: 12th Nov 2009, 05:16 -
I just adeed another 2GB Memory and Total says 3.25GB Memory
By videocheez in forum ComputerReplies: 17Last Post: 11th Feb 2008, 06:19 -
Is this Normal with 6 gigs of memory?
By ineedhelp007 in forum ComputerReplies: 13Last Post: 11th Jan 2008, 17:59 -
I'm still trying to determine how much memory is in thus USB memory stick.
By zzyzzx in forum Off topicReplies: 4Last Post: 5th Nov 2007, 14:31
