i have a .DV file from a after effects cs3 project i would have made a .AVI file but the program is so buggy that any AVI files are corrupted, so we made a .DV file which works ok, i imported the file into sony vegas pro 8, but that program add black bars to all four sides on export, so does anyone know which program i need to export the .DV file back to my cam, thanks.
Our Enosoft DV Processor can do that.
It can natively read raw .DV files and send them to any attached DV cam. Just select the file, select the camcorder and press run.
It is free for personal use. If you need the capability for non-personal use but don't need the full features of the program (i.e., cannot justify the cost), the raw DV handling part is available separately.John Miller
After Effects, need to lose File Size for import.
By zerowalker in forum EditingReplies: 0Last Post: 14th Aug 2011, 16:27 -
Does changing file extension from .f4v to .flv have any negative effects?
By huntaaar in forum Video ConversionReplies: 5Last Post: 2nd Sep 2010, 11:49 -
What is the best special effects/visual effects software?
By dzsoul in forum EditingReplies: 37Last Post: 9th Aug 2010, 23:16 -
After Effects: copy effects to another composition?
By squadjot in forum EditingReplies: 2Last Post: 8th Dec 2009, 19:16 -
Do I need After Effects?
By hanexs in forum Newbie / General discussionsReplies: 13Last Post: 3rd Feb 2008, 22:06
