I have an .avi file and I want to add in a .ass file into it. How do you do that?
Results 1 to 17 of 17
If you want switchable subtitles:
You could try avimuxgui, but I guess it only supports srt. And you must have vobsub /vsfilter installed to be able to see the subtitles in the avi file.
Or make a mkv using mkvtoolnix, add the avi and the subs.
Or do you want permanent / hardcoded subs in the avi? -
You have to re-encode to burn the subtitles in.
Using avidemux is one option, that supports .ass/.ssa subs
1) Open your video
2) In the video sidebar select XviD, configure your options, like bitrate or quality, etc..
3) In the video sidebar press "filters" => subtitles => ASS . Then load your subtitles and configure your options like margins & spacing. You can preview it by pressing the preview button, or "output" view from the top drop down menu
4) You can leave the audio sidebar as "copy", this is like vdub's direct stream copy and retains the original audio
5) Format => AVI
6) Press save with extension (e.g. "myfile.avi")
Cheers -
You can't have (permanent) hardcoded subs without re-encoding, and I don't think .avi container supports .ass subsOriginally Posted by KoRatta
If you want selectable subs, you can put it into an .mkv container with mkvmergegui
If you just want to be able to playback(view), install directvobsub and keep the 2 files separate with the same name:
file.avi
file.ass -
i would like to ask:Originally Posted by poisondeathray
1.open video - you r talking about .mkv video or .avi video??
2. at video sidebar, i can't found XviD but there is "MPEG-4 ASP (Xvid4)"..is this wat u mean??
i really need help on this..i can't mux .ass with .avi... -
I think Midzuki may be correct. Avi-Mux GUI says it supports SSA and this is the same thing as ASS. Maybe you only need to rename your subtitle file to .ssa to use this program.
are you sure about this?? i tried it, but it doesn't work..Originally Posted by jman98
Technically speaking, .ASS means "SSA version 4.00+".Originally Posted by exquisite000
Modify the file header with Notepad or Wordpad --- this should
make the subtitle file acceptable to AVI-Mux GUI.
{ http://au.geocities.com/rashojin_mizuki/Main_One/ssa-specs.pdf }
P.S.: Keep in mind that NOT ALL applications can handle AVIs containing
embedded subtitles. MPC works fine. As for WMP, Gspot, MP4Box and MPlayer, ...
well... -
Can someone tell me why after re-encoding subtitles seem to appear a bit early than they are supposed to? Does anyone know how to correct this?
I do as mentioned above:
1) Open your video
5) Format => AVI
How to add ".ass" subtitles to a ..."h264" file?
By Tatsubon in forum SubtitleReplies: 3Last Post: 20th Apr 2012, 19:35 -
Hardsub ASS and convert MP4 to AVI
By siseo in forum SubtitleReplies: 2Last Post: 4th Aug 2011, 19:57 -
Hardsubbing AVI and ASS subtitle
By lonelyassassin in forum SubtitleReplies: 2Last Post: 9th Jan 2010, 12:30 -
MKV to AVI - Little problem with .ass subtitle
By Nadleeh in forum SubtitleReplies: 2Last Post: 11th Jan 2008, 08:18 -
I have a .ass but I don't know how to add it to a video...?
By darkzero297 in forum SubtitleReplies: 1Last Post: 23rd May 2007, 21:24
