Hi, I am using DVD Labpro 2, would like to know how to re-arrange or manually set the button order for menu buttons. This is because buttons linking to the VTS, VMG will always be assigned a earlier order number no matter how I set the sequence when I link them.
Secondly, may I know how to make the highlight (for menu button) return to the top when I click down on the remote (for DVD players) when the last button was highlighted. For my current project, I have to press up all the way to return to the top.
Thanks for your help.
Above the menu design screen you will see a check box marked Auto-Route. It will be ticked by default. Untick it, and you can manually draw the path that the remote will take around the buttons. You will also notice that when you untick this box, the arrows to the right of it become available. Use these to draw links from button to button for each direction on your remote. To loop a list of options so the down arrow returns to the top after the last option, simply draw a link from last to first. Remember to also go in the other direction to the up arrow on your remote can loop form top to bottom as well.
Read my blog here.
DVD LabPro encoder just stopped.
By dadrab in forum Authoring (DVD)Replies: 4Last Post: 7th Dec 2011, 22:59 -
How can I follow what title is linked to a DVD menu button?
By nzdreamer55 in forum Newbie / General discussionsReplies: 6Last Post: 11th Mar 2011, 17:46 -
Edit dvd menu button
By canaQ in forum Authoring (DVD)Replies: 8Last Post: 24th Feb 2010, 07:13 -
Tracing which PGC is played when a DVD menu button is clicked
By Cheekie_Moonkie in forum Authoring (DVD)Replies: 3Last Post: 5th Sep 2007, 14:29 -
question about dvd menu button
By HDMI in forum Authoring (DVD)Replies: 5Last Post: 23rd Jun 2007, 22:06
