Hello, i'm new here so be gentle
I have a problem with h.264 being out of sync, since i tried to use PTS Calc on a .ts stream that had been cut with h264 cutter and i got an error message.
So i encoded it has HDTV with a mp3 stream and the release got out of sync, so i couldn't get ahold of the ms~ difference.
This was made with gordian knot manually.
When i try to make a HDTV release with StaxRip and open a .avs ( see below ) it says some [0] kind of stuff has already been made, so I have to open the .dga file, but then the FPS is 50, I need it properly converted to 25.
What do i do?
And I have this in my .avs file i use :
AVCSource("C:\Recorded\1_cut.ts", fps=25, convertfps=true)
When i try to make a 720p HDTV in Staxrip it's also out of sync and 50 fps instead of 25 fps because i could not open the .avs file in staxrip, so i had to open the .dga file, which does not have any fps=25 stuff in it.
when i try to ake a 720p hdtv in gordian it gives me some range check error .. what is that?
I am right now trying a HDTV with AC3 in StaxRip I'll repost when i know if its out of sync or not, since StaxRip said it was 25 fps but i still dont know the ms~ difference.
What can i do about all this?![]()
Over and out.
Edit, its when i cut the .ts file in H264 TS CUTTER it gets out of sync.
I did a whole part without cutting and its in sync.
any other application one can check the ms difference between video / sound? other than pts calc.
ok, i did use FireDTV
How do one exactly encode HDTV / 720p HDTV, im running in to alot of problems, a nice guide anyone?
EDIT : jagabo seems that your line does not work with Gordian Knot :S
I dont get any video-preview window.
Re-Encoding 720p H.264 MKVs to 400p XviD AVIs?
By Kid Boruto in forum Video ConversionReplies: 6Last Post: 27th Feb 2011, 13:01 -
Audio out of sync problem with FFMPEG encoding MP4 (h.264,AAC)
By jenak1980 in forum Video ConversionReplies: 7Last Post: 5th May 2010, 02:03 -
HD 720p H.264 MP4 video ?????
By RunAway in forum Newbie / General discussionsReplies: 9Last Post: 24th Dec 2009, 20:42 -
Image sequence to HDTV 720p & 1080i/p (H.264)
By Alendri in forum Video ConversionReplies: 2Last Post: 29th Dec 2007, 17:12 -
Problem with encoding a .ts 1080i to 720p x264
By Gordo_ in forum DVD RippingReplies: 2Last Post: 4th Jul 2007, 14:32
