I installed a phenom 9550 processor today, everything is up and running fine, but the temp at idle is 56c - 58c, while encoding 63c - 65c,. Stock heatsink/fan.
Is my processor running hot ?? What is optimal temps for a AMD quad ?
	Your cpu temp seems high perhaps you need to reset the cpu and heatsink fan. According to AMD specs the max temp is 70c.
 http://products.amd.com/en-us/DesktopCPUDetail.aspx?id=400
	Yours is a little hotter than others are reporting:
 http://www.newegg.com/Product/ProductReview.aspx?Item=N82E16819103251
	After alot of research the Asus M3A mobo bios gives incorrect readings on the cpu temps. An Asus M3A user, changed mobo, same processor, issue solved.
 Common issue with the Phenom processors and Asus M3A mobo.
  Laptop TempsBy HotDamn! in forum ComputerReplies: 4Last Post: 17th Apr 2010, 02:29
  6 core phenom II previewBy deadrats in forum ComputerReplies: 16Last Post: 21st Oct 2009, 19:09
  AMD Phenom X4 9500 vs AMD Phenom II X3 710By kenmo in forum ComputerReplies: 16Last Post: 1st Apr 2009, 21:03
  Going from amd 9850 to pentium 9550By johns0 in forum ComputerReplies: 1Last Post: 24th Sep 2008, 00:30
  NVIDIA GeForce 6100 Vs Radeon 9550By the_importer in forum Media Center PC / MediaCentersReplies: 5Last Post: 12th Nov 2007, 17:59
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
