We did everything Panthro said, and sure enough the screen on both the TV and the DVD player said "Code 2" then after changing it to "Code 0" we paused and switched off...but when we put in a US DVD an error message appeared saying "Region zu uberprufen" (ie "Check your Region", in German) - and the DVD would not play...
Can anyone help.
Is LG 6054 more protected and less hackable in Switzerland than elsewhere?
Thanks for any advice
ZaraKate
Hate to state the obvious, but the hack isn't working. This could be because you are attempting to use a hack for a different player, a player from another region, or you may have a newer model and the hack is no longer valid.
Google is your Friend -
Try changing your OSD language to English? Setting an OSD language is a very important FIRST step in a DVDR setup (some remind you constantly if you haven't selected a language), so there might be some correlation between that language and what the machine allows you to do. I'd set the OSD language to English then try the hacks? Pretty far out but very simple to try.
How do you play a rental DVD on a pc? It won't work for me!
By candacec in forum Software PlayingReplies: 7Last Post: 22nd Jul 2010, 00:11 -
DVDs Won't Play on 1 Year Old MacBook Pros
By cyberboy in forum Authoring (DVD)Replies: 3Last Post: 22nd Aug 2009, 03:43 -
Vista laptop won't play my DVDs
By AlanHK in forum ComputerReplies: 1Last Post: 29th Feb 2008, 07:04 -
DVDs won't play on anything
By A Traveller in forum Software PlayingReplies: 3Last Post: 4th Jan 2008, 16:20 -
Insignia NS-DRVCR - Tried Hack Got It Working Now My Remote Won't Work
By GTAGamesLvr in forum DVD & Blu-ray RecordersReplies: 7Last Post: 28th Dec 2007, 06:37
