My DVD has played fine on two different laptops but effected the following two audio irregularities on two different tabletop DVD players ...
One tabletop player completely mutes the audio while another plays the audio track under a continuous high-pitched tone.
The DVD was edited and authored on "MPEG Video Wizard DVD" and burned using "ImgBurn."
How can I correct these audio problems?
Thanks.
If your movies have audio in more than one format, try selecting one of the other audio tracks. As the previous reply says, not all players will have all codecs. Some players will only support AC3 (and MP2 in Europe) -- as that's spec-compliant -- so if you are trying to play vids with audio tracks in DTS, you can get problems. If the source was a commercially-authored DVD (I know you edited and authored it, but you didn't say specifically whether you also shot it), you should have at least one track in AC3, so give that a try if it's an option.
Weird playback of a DIVX file on DVD player
By gastrof in forum Newbie / General discussionsReplies: 3Last Post: 9th Oct 2011, 21:07 -
Cedocida - "Jittery" playback on some media players/DVD players
By BertRito in forum Newbie / General discussionsReplies: 11Last Post: 4th Aug 2010, 20:20 -
Massive problem with DVD playback, weird colours/green bars/other
By Mr. SoAndSo in forum Newbie / General discussionsReplies: 4Last Post: 16th Nov 2008, 19:37 -
AVI to DVD results in weird playback fault
By JustGreg in forum Video ConversionReplies: 0Last Post: 26th May 2008, 10:51 -
Can tabletop dvd recorder attach to a computer and also to a dvr, separatel
By ItsMikeMazz in forum DVD & Blu-ray RecordersReplies: 7Last Post: 20th Jul 2007, 19:26
