Hi,
does anyone know a software for "normal" users, which can do seamless branching?
i would prefer opensource but I am also willing to pay for it, but in a normal range for private usage. professional software would be too much for my budget.
but if there aren't any solutions for us normal people I would like to know at least which software would be able to do that.
thx in advance,
Andreas
www.hdtvtotal.com | Your European Total Source To HDTV!
1st choice
eac3to----Can generate in text form the main movie MPLS file (playlist file)and all the m2ts files that make up the movie only and their proper sequence. Just load the one MPLS file into tsmuxer
2nd choice BD edit ---Can show the sequence of the m2ts files used for the main movie only. Use tssplitter to join all the m2ts files together as one and load into tsmuxer.
Much less problems using the one MPLS file (playlist file) loaded into tsmuxer.fast eddie -
Are you talking for DVD? The only tool I know of is the Toshiba authoring system which isn't sold to the public.
I am tallking about BDsOriginally Posted by videopoo
greets, Andreaswww.hdtvtotal.com | Your European Total Source To HDTV!
Blue Ray Seamless Branching
By wulf109 in forum Blu-ray RippingReplies: 3Last Post: 10th Feb 2011, 23:42 -
Play the Seamless Video Loop
By fantozzi in forum User guidesReplies: 0Last Post: 13th Nov 2009, 14:08 -
Which DVD authoring application is good at seamless branching?
By AnitaPeterson in forum Authoring (DVD)Replies: 4Last Post: 6th Apr 2009, 21:03 -
Seamless Branching
By Mirkoschieder in forum MacReplies: 2Last Post: 6th Apr 2009, 10:58 -
Branching - I think?
By damodags in forum Authoring (DVD)Replies: 1Last Post: 11th Oct 2007, 04:33
