Results 1 to 10 of 10
    Oct 2005
    I've got a rendering project of animation for work.
    When I burn files 13-16 with ConvertXDVD it gets to 37.6% every time then hangs
    and crashes.
    I tried fixing the files with Video Fixer 3.21 and no luck, same hang at 37.6%
    Even on a different computer, no idea what's wrong with them.
    USA
    What format (Codec) are they using? Most 'video fixer' programs just fix the index. Your file may have more problems. Can you open it in VirtualDub Mod? More information about the file format would help. A screen shot from Gspot posted here may help. Or try MediaInfo.
    And welcome to our forums.
    Oct 2005
    I'll get the info for all 4 files cos I don't rightly know which one is causing the hang up. Gimme a few minutes, thanks.
    Oct 2005
    Formats:
    AVI File Details
    Name.........: t213.avi
    Filesize.....: 349 MB (or 358,334 KB or 366,934,016 bytes)
    Runtime......: 00:44:57 (64,664 fr)
    Video Codec..: XviD
    Video Bitrate: 892 kb/s
    Audio Codec..: ac3 (0x2000) Dolby Laboratories, Inc
    Audio Bitrate: 192 kb/s (96/ch, stereo) CBR
    Frame Size...: 624x352 (1.77:1) [=39:22]
  5. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Post an actual g-spot screenshot of the files.
    Read my blog here.
    Oct 2005
    Apr 2004
    Miskatonic U
    Try updating your G-Spot. The current version provides a lot more information about the file that the old 2.21 you are using.
    Read my blog here.
    Oct 2005
  9. When you use the "check" function in video fixer, it should tell you if the file is ok or has an error - that way you might be able to narrow down the problem
    Can you play the problem file back in mpc or vlc? Is it seekable? Is there a glitch at a certain time?
    If it is playable, you might get around the problem by frameserving and encoding into an intermediate file for that error file, and using that intermediate file as input into convertx. (e.g. use directshowsource() and avisynth) - actually if that works, you could directly enter the .avs for the problem file(s) as input into convertx
    Oct 2005
    The check function comes back as the file is fixable. No errors display in the log window. The files play fine as well in both mpc and vlc.
    I'll check into it thankyou!
