hi all
i rescued with Tuneup2008 my mov files, which i deleted accidentally 1 day befor. (made by a kodak camera)
and now i have a problem to work at it. none of my players can encode them
i find the Mplayer and try to convert them, but it shows me only the following infomation
what is moov atom? is it repair-able?? or are there something to rescue part of them
i need them for a project in collage...(snif)![]()
thx a lot and sorry for my bad english
dont know where i can post this, so i tried here. hope the Pros can help me.
command line:
"C:\Programme\MPlayer for Windows\mplayer.exe" -slave -identify
-noquiet -wid 721948 -colorkey 0x101010 -nokeepaspect -framedrop
-autosync 100 -vf screenshot -font C:\WINDOWS\Fonts\Arial.ttf -priority
abovenormal -ao dsound:device=0 -sws 9 -af volnorm=2
G:\Bak\新建文件夹\100_0670.MOV
MPlayer Sherpya-SVN-r27081-4.2.3 (C) 2000-2008 MPlayer Team
CPU: Intel(R) Pentium(R) M processor 1500MHz (Family: 6, Model: 9, Stepping: 5)
CPUflags: MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1
Compiled for x86 CPU with extensions: MMX MMX2 SSE SSE2
Setting process priority: abovenormal
C:\WINDOWS\Fonts\Arial.ttf doesn't look like a bitmap font description, ignoring.
Cannot load bitmap font: C:\WINDOWS\Fonts\Arial.ttf
Playing G:\Bak\新建文件夹\100_0670.MOV.
libavformat file format detected.
[mov,mp4,m4a,3gp,3g2,mj2 @ 00E85D70]moov atom not found
LAVF_header: av_open_input_stream() failed
MOV: missing header (moov/cmov) chunk! Maybe broken file...
ID_VIDEO_ID=0
Exiting... (End of file)
I haven't tried Mplayer for that. I use VirtualDub Mod most times. It sounds like the MOV file may have some damage. If VD can open it, you may be able to fix it. Alternately, try opening with VLC Media Player. It can play most broken files and may be able to transcode it to something usable.
And welcome to our forums.
thx for u help...
i tried all players i have...(vlc, storm...)
VD mod show me the error of damaged files and crashed
i tried
Allok MOV Converter v2.3.0.0 (i can convert 3 of 29 to avi)
All_Media_Fixer_Pro_9.04 and 9.03 and 8.0 (they all closed automatically)
kernel-digital-media (cant help)
sigh, think it is hopeless
i go crying now...
Open MOV (HDVA) file for edit
By andrewgerm in forum Video ConversionReplies: 60Last Post: 1st Feb 2012, 01:50 -
MOV files, cant open to edit/convert
By haggisuk in forum Video ConversionReplies: 3Last Post: 12th Oct 2009, 10:16 -
MOV won't open in MediaPlayer Classic
By terrypin in forum Newbie / General discussionsReplies: 4Last Post: 4th Sep 2008, 01:56 -
Avidemux won't open mov
By Nitro89 in forum Video ConversionReplies: 2Last Post: 13th Apr 2008, 09:46 -
.mov wont open in quicktime
By lonewolfsas2k4 in forum Newbie / General discussionsReplies: 1Last Post: 4th Nov 2007, 11:25
