I want to capture some video from my Xbox 360 using one of those Dazzle capture cards, but I think you have to have a "tv/video out" signal from your TV right?
Does anyone have any ideas if I can work around this?
I have a Westinghouse 32" LCD.
"Wanting people to listen, you can't just tap them on the shoulder anymore.
You have to hit them with a sledgehammer,
and then you'll notice you've got their strict attention."
-John Doe in Se7en -
Originally Posted by jthompson99
The only workaround would be to point a camcorder at the screen. :P"Just another sheep boy, duck call, swan
song, idiot son of donkey kong - Julian Cope" -
Actually, I think my tv is considered a "monitor". It doesn't have a built in tuner even though it is HDTV.
Wouldn't work even if you had composite out from the TV. The HDTVs I've seen would show only the output of the NTSC tuner.
If S-Video you would need one of these.
http://www.buzzillions.com/dz_98781_ce_labs_av_400sv_prograde_video_reviews
Shop price.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
I connect the Xbox to the TV using component video cables.
Then get one of these.
http://www.studio1productions.com/distribution_amps.htm
And an ADS Pyro 480i analog component to DV (Firewire) transcoder.
http://www.bhphotovideo.com/c/product/462758-REG/ADS_Technologies_API_558_EFS_Pyro_A_V...rectional.html
Or one of the HAVA products that will take component 1080i or 720p in and downscale to 480i for recording to disk.
http://www.myhava.com/products.htmlRecommends: Kiva.org - Loans that change lives.
Doesn't the Xbox 360 have a composite or s-video output? Does it output to both component and to one of those at the same time? If so, you don't need a video output from your TV or a component video splitter. Just leave the component video running to the TV and run composite or s-video to the Dazzle.
If you want high definition captures you will need a high def component capture card like the Hauppauge HD PVR (hardware h.264, includes passthrough to TV) or BlackMagic Intensity Pro. -
You guys were right, I need a video distribution amp.
Thanks."Wanting people to listen, you can't just tap them on the shoulder anymore.
-John Doe in Se7en
HTPC + HDMI + Projector = "No Signal"
By IceGothic in forum Media Center PC / MediaCentersReplies: 7Last Post: 23rd Aug 2011, 07:53 -
VHS tape capture "flickering" - Intensity Pro Capture Card
By mofaster in forum Capturing and VCRReplies: 2Last Post: 31st May 2009, 12:56 -
"No signal"-capturing from VHS-tape
By Mållgan in forum Capturing and VCRReplies: 7Last Post: 19th Sep 2008, 03:21 -
VRD-MC3 "Copy Protection Signal Detected: Cannot Record"
By cmwalsh in forum Capturing and VCRReplies: 6Last Post: 14th Jul 2007, 11:03 -
Laptop vga out to LCD tv (not a "no signal" problem)
By Keystr0ke in forum Newbie / General discussionsReplies: 3Last Post: 8th May 2007, 11:15
