Hello,
novice here, wondering if anything new out there that might allow me to convert DRM WMV to either mpeg, mov, burn to dvd via idvd, or burn to vcd via Toast. Searched forums and most recent posts seem to be at least yr & a half old. Running Leopard on fairly new iMac. Any help much appreciated.
thanks,
B
				Results 1 to 11 of 11
	There is a windows program called fairuse4w. I don't know if there is a mac version available. I'd suggest doing a web search for fairuse and mac in the same search phrase and see what you find. Good luck. I don't know how many apps support wmv on the mac as it is really a windows format (although yes i know quicktime is widely available on windows also so anything is possible these days). Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
	You would still need the license to view the WMV, to be able to do anything with it. Unfortunately, as far as I'm aware, there's still no support for DRM WMV/WMA on a Mac, so you'll have to use a Windows machine to view/convert the file. If cameras add ten pounds, why would people want to eat them?
	thanks guys, I have access to a windows machine, would it be possible to just drag & drop the file into an external dvd burner?
	you would need to drag and drop it onto something that can author it
 on the windows side. I have used Nero Suite 7 on the PC
 through Parallels for this. Works fine....."Everyone has to learn, so that they can one day teach."
 When I'm not here, Where can I be found?
 Urban Mac User
	thanks TerryJ,
 machine I have access to is Dell Xp running Vista, how would I do this, and what about DRM removal via something like this: http://www.wmatomp3-converter.com/digital-media-converter.html (says it works w/mac also).
	Well by the looks of the link it is an audio converter. Wma is windows media audio - a form of digital audio in the format .wma. This is a converter to mp3 given the link you showed.
 You'd need something that handles wmv which is windows media VIDEO. Again try fairuse4w but your success will depend on what the most recent release can break.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
	I believe FairUse (as well as most of the other programs like it) does require the license file for the video, so you'll also need to play it properly at least once on the Windows machine to have that license file generated. If cameras add ten pounds, why would people want to eat them?
	Ai is correct. I usually play the video file in WMP first completely,
 and then drag and drop it into Nero to author to disc."Everyone has to learn, so that they can one day teach."
 Urban Mac User
	ok I'll give it a shot, thanks for all the timely replies. One thing I forgot to mention: does size of file matter as long as it's not ridiculously huge? File in question here is right around 1.27G.
	only thing that would pertain to is your available Hard Drive space.
 If the wmv is 1.27Gb, you'll need at least 3 times that as available
 scratch disc space to transcode the file to mpeg-2 in authoring."Everyone has to learn, so that they can one day teach."
 Urban Mac User
  WMV with DRM to DVDBy __celso in forum Video ConversionReplies: 2Last Post: 7th Sep 2010, 15:26
  Terminator 2 Official dvd drm wmv filesBy BIFFtheSTIFF in forum Video ConversionReplies: 5Last Post: 18th Nov 2009, 15:15
  How to add DRM to WMV file?By trinin in forum Newbie / General discussionsReplies: 2Last Post: 6th Jun 2009, 13:52
  DRM WMV Files On QuicktimeBy matw79 in forum DVD RippingReplies: 1Last Post: 25th Jun 2007, 07:36
  DRM WMV to AVIBy ted demen in forum Video ConversionReplies: 4Last Post: 24th May 2007, 06:20
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
