I am using Windows XP Professional Operating System.
Recently I installed K-Lite codec pack 375f (klmcodec375f.exe)
After that when I play videos from Jet audio and Media player classic there is a text about audio attributes displays on vedio screen. (see the image attached below.)
http://www.MegaShare.com/444059
How can I get rid of this display ?
WAPW
It's probably the ffdshow on-screen displays (OSDs). Find the ffdshow folder in your Start menu, then pick "Audio decoder configuration." Make sure the "OSD" option (should be near the top of the left-hand pane) is unchecked.
(It's probably a good idea to do this for the other two 'configuration' options in the ffdshow Start menu folder.)
If cameras add ten pounds, why would people want to eat them? -
Thanks Dear Ai Haibara, Your tip is working.
I removed the text on display.
Thanks again.
WAPW
fuzzy text/desktop display with Sony Bravia TV
By Bacillus98 in forum Media Center PC / MediaCentersReplies: 12Last Post: 24th Feb 2016, 12:29 -
how to get rid of text in the middle or a avi video file?
By nsctsunomi in forum EditingReplies: 7Last Post: 22nd Nov 2010, 10:47 -
Read text create audio and convert text to synced subtitles in mp4
By Philip Lean in forum SubtitleReplies: 1Last Post: 25th Feb 2010, 08:54 -
looking for good OCR software that will convert text in jpg to regular text
By jimdagys in forum ComputerReplies: 6Last Post: 27th Jun 2008, 10:38 -
Add Text to DVD & CD To Display On Player
By drtalk in forum Newbie / General discussionsReplies: 2Last Post: 8th Mar 2008, 13:35
