Hi,
Ive had a fair bit of experiance with AVI files but something has rescentley stumped me, im trying to get one of the old computers at work to play AVI files as its dead at work for a few months so its easy to sit back and watch a movie on night shifts,
System specs are:-
Windows 98SE
Intel Pentuim 3 800Mhz
128MB RAM
Installed are: -
K Lite Mega Codec pack
Direct X 8.1
AC3 filter
and all other patchs i could find info on
Now the files play fine on my laptop but when they played at work the video is flawless but the audio just sounds like static interferance, i know its not the sound card because music works and all other sounds, what am i missing?
Rob H
VLC or Mplayer...
What was the actual audio codec being used?
ffdshow is installed with k-lite pack, but you sometimes have to "turn on" the appropriate codec because it is off by default. For example, if the audio was "vorbis" you would have to go to the ffdshow audio configuration and select "libavcodec" -
Hi,
When i run media info it sends me to this website: -
http://www.iis.fraunhofer.de/bf/amm/
it says: FIRST AUDIO STREAM 127KBPS (128KBPS) 48.0KHZ 2 CHANNLES MPEG AUDIO (MP3) (VERSION 1) (LAYER 3) (JOINT STERIO)
HOPE THIS INFO HELPS
Choppy .avi playback to Xbox 360... only with .avi and only when streaming
By smitbret in forum Media Center PC / MediaCentersReplies: 12Last Post: 29th Mar 2011, 07:53 -
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
AVI playback problem
By venkman1984 in forum Software PlayingReplies: 2Last Post: 1st Jun 2010, 05:50 -
Philips 5982 & 624x352 AVI Playback Problem
By gonwk in forum Newbie / General discussionsReplies: 4Last Post: 7th Feb 2010, 15:20 -
Avi playback problem
By alliedforces in forum Software PlayingReplies: 4Last Post: 27th May 2008, 14:06
