I have this old Compaq 1700 Presario laptop with a 20 G HD. It came with ME, which is now pretty obsolete; it has about 5 gigs tied up in a D: SYSTEM_SAVE partition.
I've been fooling around with some Linux distros (which now read/write to NTFS drives). I've added all the security, etc, updates that are available for ME; ditched unnecessary software, defragged, and came to this question...
There are a couple things I need Windows for (a fussy printer for one), but I won't be upgrading anything in there anymore- Linux will let me use current Open Office & Firefox 3, and I've confirmed that the wireless works for general browsing & email... but I could use the drive space from that S'_S' partition.
I am not sure exactly what the SYSTEM_SAVE would change over the future. Can I just offload it somehow onto a DVD? Is it just a bunch of cabs? I may be unique in never having had this lappie go down, so I don't really have any idea how this partition is supposed to act if needed...
thanks!
it probably is a partition that could be used to restore the c:/ to original state in case windows went belly up. some used f12 during boot to get to the restore function. i'd get rid of it if it were mine.
Yeah, I believe it is the system-restore partition. It's not uncommon for HP/Compaq (among other manufacturers) to use that only, as opposed to giving the user a restore CD/DVD (or giving them the restore partition AND a restore disc).
If you haven't already, the setup should theoretically allow you to make a single recovery disc (couldn't say where exactly you'd need to check in ME, unfortunately). I'm not sure if making a direct copy of the partition would work (offhand, though, I don't see why not... but it wouldn't surprise me if there was some reason you couldn't.)
The question is, though, do you want to make a WinME recovery disc?
Compaq Presario A940ca
By Tom Saurus in forum ComputerReplies: 1Last Post: 29th Aug 2008, 20:27 -
I am having problems taking off compaq presario front cover. Help
By dymx in forum ComputerReplies: 1Last Post: 24th Jun 2008, 17:42 -
How do I get h264 to offload to my GPU?
By gOdiSOnyOuRsIDe in forum Software PlayingReplies: 5Last Post: 28th May 2008, 11:23 -
Can an older Compaq Presario 6301RSH Desktop use PC4200 DDR2 RAM?
By Denvers Dawgs in forum ComputerReplies: 3Last Post: 22nd Feb 2008, 00:27 -
Compaq PC won't boot with new motherboard
By edong in forum ComputerReplies: 4Last Post: 28th Jan 2008, 10:52
