Anyone?![]()
Results 31 to 34 of 34
There are two ways to do it:
1. The first way is to name the movies and the subtitle the same name. For example, the movie: Ironman.mp4 and the subtitle: Ironman.srt You have to put both the movie and subtle in the same folder ( you can find any subtitle at www.subscene.com).
2. The second way is to use software mkvmerge GUI v4.4 ( it is a free software mkvtoolnix)
. After install the software, start the program, on the INPUT tab click ADD your video file, your subtile file ( as many as you want). Finally, click START MUXING (it takes about 5 minute). Don't worry, you don't loose any quality when you have movie.mkv.
Good luck buddy
How to add subtitles permanently to existing mp4 h.264 file???
By Patrick_H in forum SubtitleReplies: 20Last Post: 7th Aug 2014, 08:35 -
Add Soft Subtitles and Chapters to m4v / mp4 (How to in Windows)
By mikec798 in forum SubtitleReplies: 5Last Post: 2nd Nov 2012, 12:49 -
Add subtitles to existing dvd movie
By woodtogo in forum SubtitleReplies: 13Last Post: 20th Apr 2011, 18:55 -
Add subtitles to an hd movie
By zoloabc in forum EditingReplies: 1Last Post: 2nd Feb 2010, 03:06 -
How can I add my subtitles in Cyrillic to a movie?
By Misterygirl in forum SubtitleReplies: 19Last Post: 17th Jul 2008, 14:51
