I have the chance of purchasing a few JVC S800U SVHS decks. I have read they do not have an internal TBC. Just wondering if these were worth getting for vhs restoration and conversion to dvd or would it be better to get a 9000 series?
It depends what optional upgrade cards are installed in the units you are considering. The entire point of using a JVC 9000 series for DVD transfers is their built-in TBC and DNR circuits, the actual underlying vcr is nothing special at all. The BR-S800U was a pro editing suite deck, these do not always play back tapes made on consumer VCRs very well because of a mismatch between "pro" and "consumer" head gap widths. You should ask the seller if the units have the TBC *and* DNR upgrade cards installed in the chassis: if they do, and you get a really great price, it could be worth a shot. Without those optional cards, I would pass- they will be no better than a $20 consumer VCR for DVD transfers.
Beautifully built, rugged, pro-looking and damned heavy, yes, optimized for DVD transfers, no.
JVC BR-S800U issues.. (..and Sony UVW-1800)
By Veepa in forum Capturing and VCRReplies: 0Last Post: 23rd Aug 2010, 20:13 -
Restoration project: Need advice buying a decent VCR.
By nicknick in forum RestorationReplies: 35Last Post: 12th Apr 2010, 11:14 -
CloneDVD2 - worth buying with AnyDVD or not?
By trimicada in forum DVD RippingReplies: 14Last Post: 23rd Dec 2009, 12:52 -
Avanquest ConvertMovie worth buying?
By guitareth in forum Video ConversionReplies: 2Last Post: 12th Jul 2008, 11:42 -
Professional Video Restoration VS buying my own Hardware. (VHS/BETA to DV)
By HOTPROPHET in forum Newbie / General discussionsReplies: 4Last Post: 15th May 2008, 12:47
