Oh, what a pity. I'm so sad, crying endlessly. Really need your help guys. I'll state my issue short. I just got a DV camera (I'm pretty/totally new on this whole video stuff anyways) and want to preserve my footage in a smooth way, where both quality _and_ those megabytes of storage is a real issue.
So, I found that H264/X264 would be the perfect sollution, where X264 even offers a 'lossless' option for those really great moments (weddings, funerals, etc). So, perfect, I thought.
Everything works fine. I needed a simple ACM hook that could integrate the encoder directly into Sony Vegas encoding options. So, X264vfW (http://sourceforge.net/projects/x264vfw/) seemed like the best solution around. Worked like a charm - almost(!!).
Let me start from the beginning. My raw DV video is 720x576 (DAR 4:3). At first, when I encoded the video as MPEG1/MPEG2 streams, they appeared correct in my "to-be-burned-as-dvd simulation" (which I used Nero Vision for), with only some "black area" in the top/bottom area, just like when you watch a movie on your 4:3 television, if you know what I mean.
However, then when I finally got to try out the Xvid codec, annoying black field in (not only) the bottom/top area appeared in the Nero Vision preview, but also in the left/right. From what I've heard, this flaw(?) is what's called "letterboxing", "panscan", or whatever.
However, I'm not that interested in all the tech stuff, 'cuz I really just need a simple template to get the (to me) proper 4:3 look in my DVD 4:3 project. So, anyways. I was stuck to the more-megabyte-demanding MPEG2 encoding,, until..! One day, I found a new tab in the Xvid encoding dialogue box. I could chose encoding "via" Display Aspect Ratio (with choices square, 4:3, 16:9) and Pixel Aspect Ratio (same values). I had guessed that default would do, since I assumed that 4:3 _were_ default. However, just-simply-because, I tried entering DAR/4:3 and push just one more encode. Whoa, when I dragged the .avi into my Nero Vision project and previewed it, it looked alright. No loss of the video (croping or what-so-ever), just wonderful.
So, anyways..
Now I'm sitting here with the X264 codec. The problem is, I can't find any DAR/PAR dialogue (or even a command-line syntax for the pure x264.exe). All I find is a setting over "Sample Aspect Ratio". So, I've done some research, and found that SAR is apparantely the same as PAR, just a more "l33t" way of saying it, an expression to be used only by the most wise of the four wise guys, so to speak! ^^ Cool, so I tried entering "4:3" for SAR value; pushed encode. But when I drag the resulting .AVI file to my Nero Vision project, I have those annoying black "letterbox" (???) fields in the left plus right. Gaaaaaaaaaaaah, I thought I'd never have to see them again.
I'm really stuck, and I only need a quick and easy "newbie template" on how to set this with X264. The worst answer I can get on this post is "I'm sorry, but you can't!". That would make me cry out a river. However, I hope for someone to have a smooth solution.
Thanks for every single answer. And please excuse me for my poor english, I'm a Scandinavian boy under stress.
	So, after a bit more of research I guess my question would be: What's the correct Sample AR value for ordinary 720x576 DV material over DAR 4:3..? Would that be 12:11? Strange, in that case. I sort of tried 12:11 first thing I did ('cuz I had those digits somewhere in the back of my head, dunno where they came from, really), but it didn't work out. Drop dead gorgeous!
	Yes, assuming the inner 704x576 contains the 4:3 image, set x264's SAR to 12:11. If the full 720x576 contains the 4:3 image use 16:15. Does your playback software not respect the setting?
	Well, when I watch the resulting .AVI files at my computer (using recent-build MPC) I get the same view regardless of setting the SAR at 4:3, 1:2, or 100:3 (I've tried). It's when I throw the video file into Nero Vision (making it to a DVD project) I get to see how the result will look on a television screen (I gotta give the Nero Vision 'tv simulation' a bit of props 'cuz it has helped me alot hehe). Here, I see that when I burn this .AVI on a DVD, I will get the black fields all around the picture (left,right,top,bottom). In other words, exactly the same way as when encoding my 720x576 DV footage with Xvid, _not_ setting the DAR to 4:3 but leaving it to default 'square pixels'. So, my guess is that, well, I'm not sure at all.
 This question about whether inner/full, I cannot really give a 100% answer to, not being so familiar with the terms. Anyhow, I'm working with raw/unmodified DV footage from a Sony Handycam DCR-53E, which is told to be 720x576.Drop dead gorgeous!
	One option is you can set any aspect ratio at the container level by using the .mkv container (using mkvmergegui). This works on all software players for PC playback; but the problem is if you plan to convert to DVD, I'm not sure if your DVD software will ignore it.
 I don't use the vfw x264 version, but for the cli version in MeGUI, you have to signal the encoder in avisynth in the .avs script. I'm 100% certain this works, I've used it for different aspect ratios and it is encoded at the "stream level" regardless of container. For a 4:3 DAR you would put:
 global MeGUI_darx = 4
 global MeGUI_dary = 3
 Did you try using --sar 4:3 manually in the vfw add command line box? (I'm not sure if the GUI is broking in the vfw version, there's a few things missing)
 Finally, I don't use Nero Vision, but is it possible that it might be causing the issue?
 Good Luck
	Thanks for all the help guys. In some way, it must have overlooked the SAR that first time I tried (using 12:11 as I - like I said - had those numbers in my head from somewhere). Tried it again, and now it works like a charm. Problem solved!  Drop dead gorgeous! Drop dead gorgeous!
  Aspect Ratio HelpBy darkdream787 in forum Newbie / General discussionsReplies: 1Last Post: 27th Oct 2011, 03:53
  16:9 Aspect ratioBy jeffh123 in forum Video Streaming DownloadingReplies: 5Last Post: 30th Aug 2011, 20:44
  ASPECT FIX 264 - From 2:35 to 1:85 - How?By jlrm365 in forum Blu-ray RippingReplies: 1Last Post: 24th Apr 2010, 11:20
  Aspect RatioBy thesuperhemanshow in forum EditingReplies: 0Last Post: 5th Jan 2009, 17:36
  Aspect ratioBy Digiface in forum Software PlayingReplies: 2Last Post: 24th Aug 2007, 13:35
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
