Ok, so I'm dropping my .MOV (Sor3) file into the correct field, making sure the setting in the FLV field are correct and the file is the same size and frame rate as the QuickTime but when I press encode I end up with a file of zero kb. What am I doing wrong?
	This might help:
 Encoding started on Fri Jul 11 09:26:08 BST 2008
 FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
 Mac OSX universal build for ffmpegX
 libavutil version: 49.0.0
 libavcodec version: 51.9.0
 libavformat version: 50.4.0
 Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Users/makwilson/Movies/Animation ReelML.mov':
 Duration: 00:02:30.8, start: 0.000000, bitrate: 784 kb/s
 Stream #0.0(eng): Audio: pcm_s16be, 22050 Hz, mono, 352 kb/s
 Stream #0.1(eng), 25.00 fps(r): Video: svq3, yuv420p, 640x480
 Could not find input stream #0.3
	Though I'd found the problem as 3 plugins/codecs? hadn't been loaded. But no, now I get:
 Fri Jul 11 09:34:44 BST 2008
 Codec type mismatch for mapping #0.0 -> #0.0
	The same issue has come up before:Originally Posted by makman
 https://forum.videohelp.com/topic341561.html#1810515
	I have found a simpler workaround, which is that you encode from .mov to .mp4 using x264 (mencoder) at the same size and bit rate, then go to flv from there. This has worked great for me with DVD-sourced video at high bitrates, but I haven't tried it with source material at lower bitrates.
  FLV to WHATEVER NOT HAPPENING ANYMORE (MAIN@L3.0)By Telomostro in forum Video ConversionReplies: 0Last Post: 6th Jun 2009, 16:58
  .mov to .flv?By hoodsmommy in forum ffmpegX general discussionReplies: 0Last Post: 25th Jun 2008, 21:04
  Divx to FLV to MOV to FLV again, just for the sake of some effects?!By ayyash in forum Newbie / General discussionsReplies: 2Last Post: 5th May 2008, 21:19
  .flv to .movBy dth in forum MacReplies: 1Last Post: 18th Dec 2007, 18:00
  .mov to .FLVBy calthorpe in forum MacReplies: 1Last Post: 6th Jun 2007, 18:08
 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
