Hi I got 2 problems. I want to burn a 700mb .avi file onto a single 700mb CD. I have searched many guides/tuts on Google and don't find what i need. I tried using Nero 8 and try to make a VCD of it, after 40 mins of encoding Nero changed the 700mb into a 1GB file. I understand how that happened, that's because .avi file is supposed to be compressed, just like .mp3. So after changing to the VCD format, it's larger.
But i just want to burn the 700mb file as it is onto a 700mb disc. Is this possible without too much of a hassle?
I know i can split the 700mb .avi file into 2 parts using AVI Splitter, and then burn them separately onto two 700mb CDs, but that's going to waste more time for me and i would much like it better to just burn it straight on a CD.
I don't wish to waste a DVD just for a 700mb movie. I know heaps of ways to burn it to DVD, and i have used heaps of tools before. But i don't want that. I think it's too much of a waste for a DVD, sure i can use programs like DVD Flick, DVD Santa, DVD FAB Platinum, ConvertX to DVD etc, there're HEAPS of those tools i can use and i've used hundreds of them before. But i don't wish to convert a 700mb file to a DVD format, because it's just making the file larger and wasting a DVD and also wasting more time.
So anyway, i don't wish to waste my DVDs on a 700mb movie, i need the DVDs for other things more important than this. I just want to burn the 700mb file as it is without making it larger or anything. And imagine people who doesn't have a DVD writer, they can't do it this way then, so PLEASE DON'T SUGGEST anything related to what i just said.
Please RECOMMEND "ANY" tool that will do the job.
Now, i know it's getting a bit annoying and pretty long already but here's my 2nd question. Is there any tool that can convert/comrpess a 4.7GB DVD movie into a 700mb file? I've found a few guides on Google but those take too many steps as well as using 3 programs and A LOT of time just to do this. I just need a simple program that does everything for me. I don't want to manually configure the encoding settings etc, there're some burning softwares that makes u do all this work and that's just plain annoying and waste of time.
If you have a Divx type DVD player, then just burn it as a data disc with ImgBurn. I'll assume it's Divx player compatible. Otherwise you would need to re-encode it to a proper Divx format.
If you want to play it on a regular DVD player, you don't have much choice as you would need to re-encode it to a MPEG format, either VCD, SVCD or DVD. It would need 2 or more VCDs, 2 SVCDs or one DVD.
If you want to convert a DVD to Divx/Xvid, try AutoGk.
And welcome to our forums.
I use the free program ImgBurn to burn files to discs
http://www.imgburn.com/
A AVI file that is 699 MB (733*986*816 bytes) large fits on a 700Mb CD disc
Just burn it as a Data disc
You can use FairUse Wizard to convert a DVD to a 700Mb file
http://www.fairusewizard.com/
My tip is to download FairUse Wizard from the VideoHelp site
https://www.videohelp.com/tools/FairUse_Wizard
Click on the "Download from mirror download" linkHubba hubba zoot zoot.......... :) -
hi and thanks for the replies guys. I'm not sure if my DVD player can play .avi files or not, is there a easy and fast way to check? Sure i could burn it and test it but how can i tell if i just look at the DVD player?
and as for the XVCD format with lower video bitrate, that means the video quality is worse rite? -
Usually there are a bunch of logos indicating what formats it can play: egOriginally Posted by chaoscreater
DVD
VCD
MP3
DivX
And most Avi files are actually DivX. Use a program like GSpot to tell for sure.
Of course, it should be in the manual too.
And a blank CD is about 20 cents, so it's not a large investment to just suck it and see.
It's often useful to have a few CDRWs for playing around and seeing what works. -
Yes, it's free and pretty easy to use.Originally Posted by chaoscreater
Can the AVCHD disc be played by the PC DVD drive (non blu-ray) and software
By coody in forum Software PlayingReplies: 3Last Post: 26th Aug 2010, 19:15 -
burning mkv file and separate srt file to play on dual layer disc
By julie_152 in forum Newbie / General discussionsReplies: 1Last Post: 29th Sep 2009, 12:26 -
avi file from hypercam is flickery when played in dvd player on tv
By west1745 in forum Video Streaming DownloadingReplies: 6Last Post: 10th Oct 2008, 14:17 -
Gray shade in subtitles when [b]avi[/b] file is played in standalone player
By huRO in forum SubtitleReplies: 2Last Post: 1st May 2008, 15:15 -
Can a SVCD video file be burned on to a DVD and played in a DVD player?
By dvdnewbie64 in forum Newbie / General discussionsReplies: 9Last Post: 17th Apr 2008, 21:44
