  1. Need Help Hope i'm in the right forum.
    Trying to convert an Movie (AVI) format to a VCD (MPEG) format.
    I'm useing TmpGenc to do this. I have done others witout a problem.
    I got Kiss of the Dragon movie and when I try to convert the AVI file to Mpeg I keep getting ( Index of scan line is out of Range )
    with this number on the end.(240)
    Could someone please help me.
    Thanks Roob :lol:
    Mar 2001
    Antwerp - Belgium (Europe
    Properly, the avi is corrupt.
    If your filesystem isn't NTFS (so fat or fat32) then be sure the avi is NOT larger than 2gig. If it is NTFS, then it shouldn't matter.
    Re-open the AVI in VDub and save it again to a new file (best way to save avi's is to save to a file onto another disk - not the same : read/write opperations).
    Then try again.
    Anyway, which version of TMPGenc are you using? Do you use a correct codec? Remember that a specific codec, installed on 1 system, not always is available at another system.
    You must be serten that you can open the avi (completely) at your system, so best way is to open it in vdub and save it from vdub to another file.
  3. Thanks for your help Betamax my file system is fat32 and the AVI file is 244mgs.
    This is all new to me. what is VDUB and how do I open it and save it with VDUB.
    I am using TMPGEnc 2.5. I have put Nimo Codec Pack 4.4.
    I opened the AVI file completely in Windows Media.
    I am using Windows XP Home Edition
    Thanks Again Roob
  4. :x
    whats up im using VDUB right now and it seem to work good im doing a file that i downloaded off morphues sorry if i spelled it wrong and it seem to be working pretty well and i like it, its good thanks
