I HAVE TRIED THIS ONE, BUT CANT GET A RIP. ITS REGION 1.
DVD SHRINK AND DECRYPTOR KEEP TTELLING ME I HAVE ERRORS IN THE REDUDANCYS.
I TRIED WITH ANYDVD, NOTED SAME RESULT.
THANK YOU.![]()
Results 1 to 9 of 9
In Dvd Shrink after it gives you the error click the reauthor button look for the main movie title right click it select add and click the backup button.You can make a movie only copy this way with anydvd activated.You can check the anydvd forums also.
Hello and welcome to Videohelp.com. A place where DVDShrink is known to be obsolete.
Try DVDFab HD Decrypter. There is a new version available on the Videohelp homepage. Also try turning off the capslock key. It usually considered impolite to only type in uppercase. That went out with the Apple][ a long time ago. Its called shouting. I sure did I like it when I modified my brother's Apple ][+ with the shift key mod. Real typing at last.
DVDShrink still works on many DVDs but it hasn't been updated in a long time. The creator has a real job now. -
BTW - Your CAPS lock is stuck...
Redundancy errors, particularly of the CRC variety, sometimes occur when there's something wrong with the actual disc. It may not be the title after all.A job? Wow. Something alot of showerless, socially inept geeks/nerds living in Mommy's basement should look into.DVDShrink still works on many DVDs but it hasn't been updated in a long time. The creator has a real job now.I hate VHS. I always did. -
Now, now you are posting on a geek site yourself.
He apparently is working for Ahead. Its not an accident that Nero Recode looks a great deal like DVDShrink. -
Then try the suggestions that have already been made.
You have one less problem though. Your caps lock key isn't stuck. -
Sniff, sniff... at least I smell good and have a job ... :POriginally Posted by EthlredYes indeed and the resemblance is no coincidence IMO either. And more power to him. Sounds like he's doing well.Originally Posted by Ethlred
My point in general is that being a marketer by trade in this industry I see things differently. Don't get me wrong, the engineers, devs, coders, etc are the brightest people in the world. But they would stink (no pun intended) at anything else. They would have to dumb down a notch to do my job, or pretty much anything else from being so absorbed with all the code floating around in their heads...I hate VHS. I always did. -
I personally get annoyed when a troubleshooting guide tells me something lame like "Make sure your disc is clean. It may be due to dust, ...." blah blah blah.Originally Posted by greenapple
I mean, don't you get irked by this cheap filler stuff when you're reading?
But this case could be genuine. A (CRC) redundancy error occurs many times because there is indeed something wrong with the disc - like dust or a scratch, etc. and the laser is having problems reading it. This would be one time where it would be worth grabbing that disc cloth. Worth a try.I hate VHS. I always did.
Can't view "bonus video content" on Taylor Swift CD
By wild4trv30 in forum DVD RippingReplies: 11Last Post: 18th Jul 2011, 13:22 -
entire disc rip Drilbit Taylor Region1
By greenapple in forum DVD RippingReplies: 1Last Post: 13th Jul 2008, 04:09 -
drillbit TAYLOR?
By badboyzz in forum DVD RippingReplies: 1Last Post: 10th Jul 2008, 22:26 -
Problems ripping this...
By EliteMarine in forum DVD RippingReplies: 7Last Post: 29th Apr 2008, 23:18 -
Having ripping problems
By ezzye23 in forum DVD RippingReplies: 3Last Post: 25th Jun 2007, 13:30
