I just had a major crash - my daughter turned every light on upstairs and then plugged in a hair dryer that you could dry airport runways with and it popped a breaker. Bottom line, I had to use UBCD to pull my data off the drive and reformat. One program the name of I can't remember was the one I use to rip sound tracks off movies. I just use it to rip the opening and credits music that I like. Drat. I think it was free, and actually had a small video screen that you could monitor where you were in the movie (or you could disable it by enabling a checkbox) and I could really pinpoint where I wanted the capture to start and end. Note that it doesn't rip the video, only the sound. I have searched this website, the software listings, everything. I'm pretty sure I got it from here, or at least a recommendation from someone here but I can't remember the name of the little program. Darn. Can anyone help me? If you don't know my program, can anyone recommend one that they like?
				Results 1 to 10 of 10
	Thanks Soopa, that is not the one I had but what the heck, long as it works! Appreciate it.
	<--- Quite a few of them on the tool section that can do the job:
 Smartripper
 DVD2avi
 DGMPGdec
	Audio Extractor crashes every time I drag & drop a ripped movie into it and start the extraction. Maybe the program can't handle an entire movie, only small clips, I dunno. With the other free proggie I had, I just dragged & dropped the entire rip, then it had a slider bar and I could advance the scenes in the small monitor it had. I could set begin and end of the section I wanted to extract, and it saved it to MP3. I am not sure about the other links from SingSing, they seem to be mainly for ripping video with sound, not extracting sound only (unless I'm mistaken). Thanks to all. Any other suggestions are welcome.
	What formats are the videos? For AVI, I always just used AVI2WAV, VirtualDubMod or AVIDemux, extracted the whole audio track and edited out the part(s) I wanted.
 However, I just managed to do what you're looking for in AVIDemux - with the preview on, cue to the section you want. Set the A and B markers at the beginning and end of the section, then go to Audio > Save...
 By default, I believe it should save the audio clip as an MP3 file, but you'll need to manually add the .mp3 extension in the save dialog.If cameras add ten pounds, why would people want to eat them?
	Thank you Ai, I think you are right. I have a wicked long drive to work, and I enjoy listening to themes and parts of certain movies. My stupid for losing that little utility in my crash, I should have had it backed up. What's that old song from the 70's? Oh yeah, Big Yellow Taxi - "you don't know what you got til its gone". However, I will say that AVIDemux may not have the slick interface the other had, but it reproduces the quality beautifully. I extracted the opening theme from Matrix and it was excellent. I then imported it into Audacity and cut out the small overlaps at the start and end and saved. Thanks again for the suggestion!
	" it was free, and actually had a small video screen that you could monitor where you were in the movie (or you could disable it by enabling a checkbox) and I could really pinpoint where I wanted the capture to start and end. Note that it doesn't rip the video, only the sound"
 Try this one:
 http://www.clone2go.com/products/freeaudio.php
 It has a start-end time as well as a monitor screen for trimming; it is free.
  sound commentary in movieBy terblo in forum Newbie / General discussionsReplies: 0Last Post: 9th Dec 2009, 17:34
  no sound on my avi movieBy hardtime in forum Newbie / General discussionsReplies: 5Last Post: 21st Oct 2007, 23:28
  Main Movie has no soundBy Keesfan in forum DVD RippingReplies: 11Last Post: 1st Sep 2007, 00:32
  no sound on movieBy natty in forum Newbie / General discussionsReplies: 9Last Post: 30th Aug 2007, 06:45
  DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 19:01
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
