Hi,
I'm encoding a mkv with a .h246 videotrack and a .aac audiotrack. But i've noticed that the audio is 0.38 seconds late compared to the video.
So i wanna remove the first 0.38 second of the audiotrack to make it sync.
How can i do that without losing any quality? (AAC 48000Hz stereo)
Tnx![]()
Yeah, you can delay the audio, but the audio is late, not early.
So i need to make the audio start 0.38 sec before the video.
Don't think that's possible in MKVmerrge?
The HelpFile to MKVmerge says:
Delay (in ms): In some cases audio and video are not synchronized properly. With this option the user can offset the audio track by a given amount, either positive or negative. mkvmerge will either remove samples at the beginning or insert silence at the beginning to adjust the track.
This option is available for audio and text subtitle tracks.
How to convert a AAC audio file in a mkv file to AC3?
By wolvie77 in forum AudioReplies: 4Last Post: 13th Mar 2012, 21:59 -
how to edit h.264 he-aac ts videos
By jamespoo in forum EditingReplies: 3Last Post: 1st Mar 2011, 22:10 -
Convert AAC 6ch to AAC 2ch w/ Dolby Pro Logic II Surround info
By SiegeX in forum AudioReplies: 5Last Post: 28th Dec 2009, 16:58 -
Edit, add, extract WAVE and edit file tags with new Machete 3.5
By MacheteSoft in forum Latest Video NewsReplies: 0Last Post: 23rd Dec 2009, 10:05 -
How to edit MP4 with AVC video and AAC audio?
By nonexistent_entity in forum Newbie / General discussionsReplies: 3Last Post: 25th Sep 2009, 06:58
