Capturing TV (PAL), for authoring DVDs, is there a software (or software/hardware combo) that enables capturing directly the Dolby Digital sound via the SPDIF output in my Satellite SetBox output to my PC SPDIF input?
Yes.
Very specific hardware requirements, then a software conversion necessary, but it definitely works. Do a search for my name and SPDIF, post back with further questions. -
Thank you.
I did search, before posting and now again, yet, didn't find ant relevant answer. Would you please mention the hardware and software requirements? -
https://forum.videohelp.com/topic339168.html
That one was direct to you. There are others.
Some authoring progs do not like the high bitrate on these files, seems to cause some strange errors. Can re-encode with various progs, I used Vegas just for the compatible AC-3 engine, but BeSweet worked as well.
Haven't nailed down whether the high bitrate caused the minor de-synch I was experiencing, the work-around described solved it but am still seeking an easier method.
Full 5.1 surround is nice, though. Only recently was able to run cable for rear speakers after unscheduled departure of the Domestic Decorating Advisor.
Dolby Pro Logic vs Dolby Digital?
By therock003 in forum AudioReplies: 17Last Post: 11th Jun 2011, 20:51 -
How to decode Dolby Digital from SPDIF input?
By Try4ce in forum AudioReplies: 12Last Post: 17th Feb 2009, 17:53 -
By x2srj in forum AudioReplies: 0Last Post: 8th Sep 2008, 07:48 -
From Dolby Digital AC3 to Dolby Digital Stereo and back
By moviebuff2 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Dec 2007, 20:54 -
How to downconvert Dolby Digital to Dolby Pro Logic II?
By randyharris in forum ffmpegX general discussionReplies: 0Last Post: 2nd Nov 2007, 17:54
