Capturing TV (PAL) via VirtualVCR (and VirtualDUB), for authoring DVDs, I can choose between YUY2 and UYVY. What's the difference between the 2 and which will give better quality?
The only difference is in the ordering of the Y, U, and V components. They are both 4:2:2 chroma subsampled. Quality will be identical.
http://www.fourcc.org/yuv.php#YUY2
http://www.fourcc.org/yuv.php#UYVY
YUY2 vs RGB24 vs Y800
By 201flyer in forum Software PlayingReplies: 40Last Post: 28th Apr 2011, 07:11 -
How to take stream in -> decode to file (UYVY)
By zakeboy in forum Video Streaming DownloadingReplies: 5Last Post: 28th Aug 2009, 14:30 -
YUY2 Codec for Quicktime?
By EZ-Fan in forum Software PlayingReplies: 1Last Post: 12th May 2009, 09:07 -
uyvy video format
By joshalb in forum MacReplies: 3Last Post: 22nd Oct 2008, 15:28 -
YUY2 or RGB for vhs capture?
By RH+ in forum Capturing and VCRReplies: 2Last Post: 3rd Nov 2007, 13:46
