I've got this MP4 file which I want to convert to DVD. I've read some guides and searched the forums, but been unsuccessful so far in finding an answer that works. The MP4 contains as far as I can tell H.264 (AVC1) video and AAC audio. I can play it on the computer perfectly well. I have CoreAVC. My main problem is getting the audio out of it. Normally I do this with GoldWave which works very well, but in this instance GoldWave doesn't recognise the audio stream. Nor can I open the mp4 in VirtualDubMod either to demux the audio stream.
I have installed and configured the latest ffdshow codec pack as per a guide I found and I can open the mp4 directly in TMPGEnc if I enable the ffdshow filters to handle it, but again the audio is proving to be a problem. How is this done?
Results 1 to 17 of 17
Sorry for bumping a year old thread but I would like to know how I can open .mp4 files in VirtualDubMod as well.
Where can I find/enter DirectShowSource("pathtoyourfile\filename.mp4") in VDubMod?The further away I get from the things that I care about...
the less I care about how much further away I get... -
Make a text file with that line in it (be sure to change 'pathtoyourfile' to the correct path/directory your file resides in, and 'filename.mp4' to the correct name of your video), then save it under whatever name you want, with the extension .avs, and load the .avs file into VirtualDubMod as you would a video. Note that you must:
A) Have AVISynth installed.
B) Be able to play the video using DirectShow (have the proper codecs/filters installed).
Alternately, you can select Open video file... from the File menu in VirtualDubMod (or hit Ctrl-O). In the file-open dialog window that pops up, there should be a dropdown at the bottom of the window with the label Use AviSynth template. Pick 'DirectShowSource' from that list, change the 'Files of type:' dropdown above it to 'All types (*.*)', then load your MP4 as you normally would.
If you don't want to mess with AVISynth, you might take a look at one of the editors that can load and work with MP4 directly, such as AVIDemux. (Edit: Oops, forgot. If you're just looking to extract streams from an MP4, like the topic's title mentions ('How to extract AAC audio out of MP4'), you can also just demux the MP4 using YAMB.)If cameras add ten pounds, why would people want to eat them? -
(reads comments on VideoHelp's Tools page for YAMB)
I apologize. I didn't know there were any issues with the most recent (beta) versions of YAMB.
I haven't even used it in a long time (haven't had a need to mux/demux an MP4, for example), so I just have an older version installed on one of the systems here. Haven't tried uninstalling it, either - though now, I'm not sure I should, if I wanted to.
LoL, yeah I found out afterwards.
Luckily I have a Acronis image backup and could recover my start menu with a few clicks. I would've been a nightmare to recreate all my shortcuts.The further away I get from the things that I care about...
...except you'd have to spend $1,000+ to buy Final Cut Pro (for your Mac), if you didn't already have it, when the task can be accomplished using much simpler freeware/shareware programs (on Windows, OS X or Linux).Originally Posted by oposky2006
gOdiSOnyOuRsIDe: I wonder why the YAMB devs haven't seemed to fix the problem (or mentioned it on their website)... or even pulled the beta and corrected it, as it sounds like it could be an issue with the installer. From the comments on the Tools page, it's even happened to people across more than one beta version.
The version I have was installed as part of another package, and just claims to be v2.0 (with a date of September 9, IIRC (I forgot which year
)). I think I've already tried uninstalling it more than once on more than one system, so maybe it doesn't have the problem... I hope.
It could be your start menu shortcuts are all location in the "All Users" folder and not in the "YourUserName" folder. This bug seems to only affect the "YourUserName" start menu shortcuts.Originally Posted by Ai HaibaraThe further away I get from the things that I care about...
Oh, no, I haven't lost any of the Start menu entries/shortcuts. I'd done all of that uninstalling/reinstalling (the program that included YAMB) before I knew about the issue, though.
It might not have happened because the program may have used its own setup for installing YAMB and not YAMB's own installer, or the issue started with a later version, I don't know.If cameras add ten pounds, why would people want to eat them?
MP4 w/ AAC ---> MP4 w/Compatible Audio
By NotSoEasy in forum Newbie / General discussionsReplies: 3Last Post: 26th Aug 2011, 15:41 -
Convert MP4 AAC Audio possible?
By kazz0817 in forum AudioReplies: 4Last Post: 18th Apr 2011, 02:42 -
Extract AAC audio from mp4 file
By vampypiano in forum AudioReplies: 3Last Post: 25th Jan 2011, 22:28 -
Convert h.264 MP4 w/AAC 5.1 audio to AVI file w/AC3 5.1 audio for Xbox 360
By ycrazyy in forum Newbie / General discussionsReplies: 6Last Post: 14th Jan 2010, 15:25 -
MP4 (x264 / AAC / 720x480) to MP4 (x264 / AAC / iPod res)
By GrayStrickland in forum Video ConversionReplies: 2Last Post: 15th Jun 2009, 10:20
