When I boot up Windows XP SP2 The Pioneer DVR-115d is listed in my hardware profiles, but is unusable. It doesn't recognize any cd or dvd I put in it. This is the case with both in different computers with the same WinXP SP2.
In explorer Windows sees TWO drives (both a DVD-RAM drive and a separate CD-ROM drive). But neither will list the content of any disk. Note: there is only one physical drive in each machine so this doesn't make any sense.
Buy a new 80 wire ide to connect your PIONEER 115D drive. If you don't use a 80 wire ide cable the drive will not work correctly.
P.S. To any moderator this thread should be in the DVD REWRITER section.
How do you make Pioneer DVR-115D Region free?
By scan_disk in forum DVD & Blu-ray WritersReplies: 16Last Post: 12th Dec 2008, 23:37 -
I/O errors with my new Pioneer DVR-115D burner
By gshelley61 in forum ComputerReplies: 4Last Post: 12th Jul 2008, 15:25 -
Replace Pioneer DVR-104 with DVR-115D? EIDE cable the same? Other questions
By Goldenvoice in forum DVD & Blu-ray WritersReplies: 1Last Post: 13th May 2008, 08:20 -
Pioneer DVR-115D Firmware Upgrade
By G13 in forum MacReplies: 3Last Post: 23rd Apr 2008, 02:14 -
FYI:Pioneer DVR-115D Firmware Update
By pepegot1 in forum DVD & Blu-ray WritersReplies: 3Last Post: 31st Jan 2008, 13:50
