You were lucky, Much of the Malware will disable System restore.Originally Posted by GideonK
Results 31 to 34 of 34
If you have no problem except when trying to browse and you do not want to format and reinstall OS etc, switch to a different browser such as firefox3 and make it your default browser. In the old days when DivX used to come with adware, ii did not mind it because it did not affect me. I was using Mozilla and not IE
Listen or not, it's no big deal to me. When a system is as seriously affected by malware as yours is, it's futile to try to "clean" it with scans. You need to reformat and reinstall Windows. Some of the malware digs in real deep and is able to reinfect a system. Another problem is that some of these malware programs alter system .dll's and other components. So it isn't just a matter of removing the malware. When this occurs, your OS has been damaged and it takes more than just removing the malware to fix your system.
It takes a little work, and some research, and some persistance. ONE scan, ONE fix will simply not do it.
Windows explorer, C:\windows\temp, c:\documents and settings, username(do all), local settings, temp.
Now if you come back and say you can't find local settings, just give up and re-format.
They can all be removed, ain't seen one yet that can't. Personally, re-installing all my apps is not such a joyful thing.
Going nuts trying to convert a video
By ehunter in forum Video ConversionReplies: 38Last Post: 19th Mar 2010, 09:50 -
Bugs Bunny is driving me nuts.
By G)-(OST in forum Off topicReplies: 15Last Post: 24th Jun 2009, 21:52 -
DVD Burner going nuts?
By Immortal25 in forum DVD & Blu-ray WritersReplies: 3Last Post: 31st Jan 2009, 09:32 -
Printer driving me nuts
By bryankendall in forum Newbie / General discussionsReplies: 4Last Post: 27th Dec 2008, 08:47 -
This cdex is driving me NUTS!
By Jo The Veteran in forum AudioReplies: 4Last Post: 18th Oct 2008, 08:26
