Hi - first off - apologies if this is not the correct thread to post in but is definitley seems a "noob" type question.
I've searched the site and can't find any guide to printing CD/DVD Labels ( not covers - they work fine).
I've scanned a few CD/DVD labels and whenever I import them into my label printing prigram - epson easy CD Print - the printed label is always smaller than the actual label surpace - by about 2-3 mm all round the outside of the disk.
What are the dimensions I need to resize my images to to make them fit ? - and what's the easiest way to do this ?
Thanks,
Jim
Results 1 to 9 of 9
I know what to do to fix this, but I'm not sure how well I can describe it. What you have to do is take the scan and crop it so that you have the edges of the photo right at the edges of the CD/DVD you scanned. It will look something like a circle exactly inside a box where the circle goes right to all 4 sides of the box. I use a program called HyperSnapX to do this cropping. I save the cropped photo and then it prints correctly.
You should check settings of your label printing software. They usualy allow to "overscan" print so it is larger than DVD by some amount. After printing all DVD surface is covered.
Thanks - the Epson Prog. doesn't seem to have much configurability - it does seem to allow you to specify "non-standard" sized DVD/CD sizes so perhaps that might work as a "reverse engineered" version of what you say if I set a custom "slightly smaller" DVD size.....
Worth a try
I would go the other way. If you set smaller DVD size, than it may print even smaller picture. For lager size it will stretch it.
The easy way to deal with this is to use the drag handles on the image when it is loaded into Epson Print CD and size the image so that it fits. These drag handles look like little squares centered on the edges of the top, bottom and sides of the image on screen. Just click on one of the squares and drag it one way or the other while holding the mouse button down.
This was the answer - small border needed cropped from original image - thanks to all for the helpOriginally Posted by jman98
Epson print CD/Mac - photo editing for DVD label question??
By dvdguy24 in forum MediaReplies: 16Last Post: 20th Aug 2010, 04:51 -
Software ideas for full size DVD case sleeve printing please.
By EagleW in forum MediaReplies: 3Last Post: 29th Apr 2010, 01:15 -
How to fit the large size picture to the smaller size for print?
By coody in forum ComputerReplies: 7Last Post: 1st Apr 2009, 08:46 -
Printing a Color label on a disk
By tealmarlin in forum Newbie / General discussionsReplies: 3Last Post: 8th Jan 2009, 10:40 -
DVD Label Printing Advice Needed
By jday in forum Authoring (VCD/SVCD)Replies: 3Last Post: 14th May 2008, 19:35
