Does anybody know why i can hear sound,but see no video,when i try to play some avi/divx files?
you need the codecs.
go to the tools section and scroll down to the codecs section and get DivX 3.11 Alpha, DivX 4.x, and the smr patch
note
do not allow DivX 4.x to decode DivX 3.11 contentpeace out,
dumwaldo
AWW MA! you know i'm not like other guys. i get nervous and my socks are to loose. -
Thank you,i have installed DIVX 4.12 + the Playa,and i have told it not to decode divx 3.11(i had that codec) is that ok?? What does SMR patch do??
the smr patch will allow you to play video that was encoded using the navi method.
the group shadowrealm releases re-encodes and original rips using this, if you see (smr) in the title you will need the smr patch to view it.peace out,
dumwaldo
How to convert WMP v9 (VC-1 Simple/Main) to divx/avi?
By ericdunn in forum Newbie / General discussionsReplies: 12Last Post: 28th Apr 2012, 17:09 -
anybody had any luck with playing divx softsubs in Wmp 11 ?
By davexnet in forum Software PlayingReplies: 1Last Post: 12th May 2011, 01:02 -
Wmp
By aaahza in forum Software PlayingReplies: 1Last Post: 23rd Feb 2011, 03:03 -
wMP 11 Playback
By lowfell in forum Software PlayingReplies: 5Last Post: 6th Jun 2008, 09:52 -
WMP
By marlo in forum AudioReplies: 0Last Post: 23rd Nov 2007, 15:50
